Well, this went South in a hurry. I cleaned all the spark plugs and reinstalled, did the usual prep and started the engine, and it fired. Not great. But it fired. Curiously, the G3X dimmed prior to start when I turned on the boost pump 1 but I'll deal with that later. Upon start I kept the key in to 1500 and then brought on Pump 2 which resulted in a precipitous drop in RPM and the engine died. I was able to replicate that twice and decided that was enough for today. There was one moment when it purred but it was fleeting.
Upon exiting the plane, fuel was dripping...from the step. Not good. Pushed it into the hangar and started taking everything apart and noticed the trail on one side of the plane in the forward area and I assumed that it was coming from aft but the trail went cold. I removed the center covers and thought it's coming from the bypass fitting area; it sort of looked like it might be damp. I cleaned the area up and slipped a piece of paper under to see if I could spot a drip and if so, which of the six possible areas could it be coming from. It wasn't coming from any of them
And yet, the smell of fuel was pervasive but I can see anything. Then I felt dripping on my sneakers, which were positioned under the opposite step. Now, I'm thinking I know where it's coming from. Here.
So I started taking stuff off...lots of covers and stuff. Now that area might look accessible, but here's what it looks like in real life:
This fitting is in the tunnel so it's block by the rudder and brake pedals, which will have to come out. So will most of the wiring, and probably the throttle cables and that's just the start.
I never could make a visual confirmation of leaking at the fitting because without a scope there's no way to see. It could be a split in the line somewhere. But at least the pool of fuel in the tunnel floor confirmed that this is the problem. It's worst possible spot to have a fuel leak to fix. Blood will most certainly be shed.
Shoving the camera up in there for a "guess shot" appeared to show fluid around one of the fittings.
This plane ain't gonna fly this year.
