Quirky Things Seen From The Air in Your RV
If it is the one I think it is, it is the largest Hindu temple in the Western hemisphere, and second largest in the World.
Chuck
I've been meaning to add this unusual landmark to the collection here and finally managed to get a couple of decent photos of it:
This is actually a (very expensive) landslide control measure, built to prevent the side of the hill from falling into the man-made lake below it.
The Clyde Dam was constructed across the Clutha River at the southern end of the Cromwell Gorge between 1977 and 1992. Over that time, several large scale landslides which would be affected by the filling of the dam were stabilised. The "Cairnmuir Slide", as this feature is called, was different - its failure surface was above the maximum lake level. Monitoring indicated there was a risk of failure of the landslide into the lake, which would create waves large enough to go over the dam, with catastrophic effects for the townships of Clyde and Alexandra.
The main problem was found to be rainwater seeping into the base of the landslide. The lower area had a general slope of about 45 degrees and this enabled it to be waterproofed with a geo membrane, weighed down with a continuous series of wire baskets filled with stone. The upper area was then waterproofed by constructing vertical reinforced earth and retaining walls following the contour, then sealing the resulting flat surfaces by spraying on a bitumen/stone surface.
There were plans to place another dam further down the river near Beaumont but cost and lobby groups prevented this, however you can still see the remanents of the huge graffiti slogan - "HANDS OFF BEAUMONT" - that was painted on the lower face of the Slide.
They transport the spice via pipeline these days. Those damn sand worms...
Zorii Bliss: Oh, funny he never mentioned it. Your friend’s old job was running spice.
Finn: You were a spice runner?
Poe Dameron: You were a stormtrooper?
Rey: Were you a spice runner?
Poe Dameron: Were you a scavenger? We could do this all night.
Star Wars: The Rise of Skywalker
Pretty cool? Looks pretty gawdy to me and a real eyesore for the surrounding land owners. There’s one of those temples in our local area and it looks so out of place in a serene hilly wooded area. So tacky looking…… but then again, just one person’s opinion
no tackier than any other church building of any other religion anywhere any time any place
