For those folks with a On-Off-Test switch which typically installed when you don't have a key switch and push to start switch installed, how do you put the PMAG in the setup mode to set the timing?
A PMAG is in a setup mode when it is powered up and P-Lead grounded which then the timing can be set on it. I can imagine this can be a pain particularly if you don't have easy access to the back of the switch to some how ground the P-lead temporarily for the setup/config mode.
