Tired of holding my breath every time I lifted an airplane with wing jacks, I set out to design a wing jack system that would be positively locking. If I'm jumping in/out of the airplane, if the hangar door is open and a breeze comes through, or if an overzealous helper leans across a raised wing, I wanted the jack to move with the wing; even if that meant moving UP!
To safely lift via a 3/8" threaded stud, the lift point needed to be kept to a minimum length. Wing dihedral, plus any asymmetry from lifting one side puts a considerable bending moment on the stud and underlying extrusion. A tiny ball-stud would work, but that would only serve a single purpose... Also wanting this lift point to double as a tie-down ring, I hit the drawing board to see what could be made to work...
Introducing, the Ti-Down ring. Turned from 6AL-4V Titanium Bar, the Ti-Down ring is strong, light (16g), and inherently corrosion resistant. The 17/32 in. hole allows a half inch nylon rope, 11mm static line (my personal tie-down rope of choice), or a chain-hook to pass through. The bottom of the Ti-Down ring is spherical, for smooth engagement and articulation within the Locking Jack Cup.
The Locking Jack Cup is machined from 2024-T3 Aluminum (with production units anodized red). The Cup affixes to long-ram jacks or bottle jacks via set screws. Additional screws can be passed through the pin-eye of the ram, ensuring the cup cannot be lifted off the ram. When ready to lift, a stainless quick-release pin is passed through the Lift Cup and the Ti-Down Ring, ensuring the assembly stays together.
The Ti-Down Ring can freely articulate 20-degrees within the cup without binding on the pin, more than enough to accommodate typical operations. Additionally, a conical rubber-backed washer is included for snugging up against the wing skin without damaging paint (see last photo).
Testing:
Of course, the first thing everyone asks is, "so how strong is it?"
This test was conducted by machining a 6061-T6 aluminum block at a 15 degree angle (to simulate dihedral, plus 12" of asymmetrical lifting). The Ti-Down Ring was threaded in, leaving 1/8" exposed thread out of the block (to simulate potential gap between the wing skin and tie-down extrusion.
Using a freshly-calibrated load cell, the assembly was placed in the shop press, and I started pumping... Over 4,000 lbf later, the Ti-Down ring sat there unyielded... To my surprise, even the Jack Cup was not deformed in the contact region. (however, the threads in the block were a bit draggy as the ring was unscrewed). I'd say any RV out there can be safely lifted by a pair of them
Ti-Down Rings are in production now, and will begin shipping this coming week! The first batch of Locking Jack Cups are on their way to anodize, and should be ready to ship early next week.
Currently, jack cups fit rams up to 1.25" diameter (typical of long-ram Torin, Big Red, Harbor Freight etc), or jack-pads of 1.5" for the oversized size. If you guys are using something else, please let me know and we'll make sure there's an option that works for you!
Here's an overview of the components, including the factory tie down rings for comparison.
Testing:
