Got an old O-320 engine off of a Cessna (probably) with the dreaded dual mag off of one mechanical output. That’s really not the problem though (though it will be solved in a future update when I try something really dumb…
The problem is my wiring. Messed up putting my new panel in and wired them to the positive… bad Ben. Now I have them sorted properly to the ground as the great googlie mooglie in the sky intended. BUT they still won’t turn off. I can ground both of them… engine starts. Ground one… engine starts. Turn them both on… engine starts. It’s a good problem I guess that the engine wants to always keep running but it does seem like a safety factor in case I bump into the propeller too hard or something.
Wiring and switches are all continuous and working. Each mag feeds into its own 12v switch and the starter is on a separate push button switch (I lose keys like crazy so nothing in my life has them).
So did I cook them into an always on fail state? Do I have to say some magic words to make them turn off? I’ve said a few words already… they might not be magic ones though.
As a bonus I’ll pre-ask this… can’t get my alternator to energize. It’s wired right now to complete the out and back loop. But if someone has some words to describe the correct wiring as if you were describing it to a small child…
I thank anyone who takes mercy on me in advance.
