Toobuilder
I recognize that this thread is specific to the DH and RV-14 installation but since there have been some sweeping assumptions cast about in this thread I think it’s appropriate to address some of them. While it may be true that the 390 and its AV configuration seems to ”require” 100ll from a certification standpoint, I question the applicability to our E-AB world. I have shown that with EFI and proper ignition management, regular old corner gas station junk fuel works fine in my PV 540. Though I have no first hand experience running car gas through an AV engine, I suspect that the superior combustion chamber and cooling design of the AV configuration will actually help the consumption of poor grade fuel. EFI and a “proper” ignition curve is like a magic spell cast over these old engines…. It transforms them into the modern era. Is EFI a more complex installation than mechanical FI and mags? A little. Electrical design is a consideration but the fuel system is not much different than other full return systems used on other airplanes for decades. Is EFI more expensive? Not if you compare retail costs between a Bendix style and EFI - it’s about a wash. So from a retrofit perspective, a builder is far ahead from an immediate financial and build complexity perspective going with Lycoming and EFI than this DH conversion. Is 100ll going away? No doubt. But how about regular old gasoline? Unless you are hunting elk in the Yukon or flying missionaries in Africa, it’s going to be a while before Jet A becomes the defacto liquid fuel IMHO.
Yes, it is now a reality that we “future proof” our builds (that’s exactly why I went with SDS for my Rocket), but I think we need to temper the decisions we make with reality rather than hyperbole. The DH may be an acceptable power plant at some point in the future, but let’s not plan for the unrealistic post- apocalyptic “Mad Max” scenario as justification for a heavy and expensive lump on the firewall today. As was pointed out, the extra up front money for the DH acquisition is likely to serve you far better parked in a simple high yield money market account. I think this build is great and wish DH all the success in the world, but drawing performance and financial based conclusions with virtually zero data is a fools errand. JMHO.
