Based on this EAA chapter testing I invested in one:
https://youtu.be/fRvQxGl4kt4
Tricycle gear vans RVs are known to flip over in wet sod or gopher holes/ trenches
Cal
Cal
Wow, great advice, and sounds like a story about 100,000 people on this site would love to hear. Did you have a chance to write it up?Consider a pair of gloves, a tool to break canopy and something useful for digging.
When my RV4 flipped, the roll bar did a good job of busting the canopy. Due to forward momentum, the roll bar bent and sunk into ground. I had about 3 inches between canopy skirt and the ground. Even if all plexiglass was removed, I could not get out. I prematurely released my seatbelts and landed on my shoulders. Then started breaking away chunks of plexiglas and digging with my hands. A difficult task upsidedown on your shoulders. Would have been better to dig hole before releasing seatbelts.
I thought I had a hole big enough to get out but ended up getting stuck. My head went through but not my chest. Luckily people in a near by house seen the crash. They came and lifted the tail of the airplane so we could get out.
What ever tool you choose needs to be easily accessible, and small enough to manipulate.
What tool is that?My EAA chapter recently held a forced landing cockpit escape test with a donated RV4 canopy.
There was a choice of one of the commonly proposed tools including the USAF surplus canopy escape one, that ubiquitous automotive glass breaker/belt slitter, a commercial pick-like escape hammer, a small hatchet, an awl, screwdriver and EDC knife.
Initial attempts from that cockpit's close confines with screw driver, punch, glass breaker and even the pick-like survival tool proved fruitless. They all apparently lacked sufficient mass since only a few inches of swing is possible. They did nothing more than leave divots after tens of strikes.
A quick successful breakout was made with both the survival hatchet and USAF tool.
Note that in both successful breakout cases, the resulting canopy shards lacerated the tester's hand, so the glove recommendation is a good one.
With that example, I installed a small demolition tool that has both considerable mass and a pry head to snap larger pieces out once the hole is made
Mounted within seated reach on the flaps motor linkage cover
Expect the best...prepare for the worst
Where ever you mount your break out tool make sure it is mounted such that the possible sudden stop doesn't cause it break free and injury you, cuz then you might not need it.What tool is that?
I am working on a source for the USAF unit. It apparently is still used in AH1 Apache. Have inquiries out, it is still being manufactured. Itis NSN 1680-00-296-8156 Canopy Breaker Tool. What is not available is the holder...I'd like to know more about the USAF device that is mentioned. Is it the one on the far left in the picture? It is hard to tell what it does, or how, by looking at that picture.
Oh I see now. For those unfamiliar: It has a heavy steel handle that is kind of like a small dumb bell, with a short stubby unsharpened knife blade sticking out from one end. It uses a quick pin to keep it in the holder.
Well, they are pretty proud of those.............Here's a single one for sale:
Military Aircraft Cockpit Canopy Breaker Escape Tool
Military Aircraft Cockpit Canopy Breaker Escape Tool. This is a rare and hard piece to find. Would make a great addition to any collection. It shows signs of wear, scratches, dings, otherwise good condition. Has a locking pin in the butt of the handle with a split ring.www.arizonacustomknives.com
And here's one at a slightly better price:
Jet Pilot Egress Knife/Canopy Breaker Tool
A note from Marv, on the us militaria forum about this item:"I have been told that these have been around for a long time , but this is only the second one I have ever seen...the only one with the mounting bracket. It is designed to break the jet canopy in an emergency. I had thought these were...www.arizonacustomknives.com
Dave
I found mine on ebay years ago and it has been attached to several different airplanes. BTW I was told that the way it's used is to scratch an "X" on the canopy then aim for the center of the X. They go back to at least the F-4, and I have seen them in an A-10.I am working on a source for the USAF unit. It apparently is still used in AH1 Apache. Have inquiries out, it is still being manufactured. Itis NSN 1680-00-296-8156 Canopy Breaker Tool. What is not available is the holder...
