A folded trailing edge seems like it would be much stiffer.
Are builders actually balancing the counterbalanced rudders?
Thought Vans said installed the kit provided lead and that was enough on the rudder...........
Wondering now..
My original -6 rudder wasn't balanced at all.
For anyone with limited aerobatic experience planning aerobatics in an RV, Van's An Aerobatic Epistle is a must read. That also took me to a lengthy article by Van and others that was submitted for publication in Sport Aviation. I don't know if it was ever published. "Aviation Courtesy"
The difference between the aerobatic RV's when compared to many other aerobatic aircraft is the wider range between stall and Vne, Epistle details how easy it is to impose a load of 20 G's on an RV by yanking on the stick at or near Vne.
It does seem that more and more folks are putting -8 rudders on their -7s, and that’s a good thing, IMO.
Part of the problem (but I don't believe it's the whole problem) may be that Van's has never issued a Service Bulletin or Service Letter for the older RV models (including the -7s) stating that Van's changed the definition of Vne from IAS to TAS. They did put out an SL for the RV-14, and they put out a POH revision for the RV-12s, but nothing for the older RVs. It's disappointing that Van's has not issued an SB or SL addressing their change of that critical safety-of-flight information. Many RV pilots are unaware that Vne is now in terms of TAS…
If I had a -7, that’s what I would do.. especially because that -9 rudder feels just too big and stiff. Those folded trailing edges feel sweeter. Isn’t the vertical different too? Like the -7 crowd would need to change the stab and the rudder together? I thought the -8 balance tab was smaller and doesn’t fit the -7 stab..
What if some people with the equipment can build the folded rudder like the RV8 but with the larger size for the RV7 and sell them? I am sure some of the RV7 owners are willing purchase a stronger design that is less prone to zipping.
The RV-7/7As are not coming apart in-flight because of wing failures.
Every design if operated within the design margin is safe. HOWEVER, some designs have narrower margins. The unzipped rudder seems to have a rather unpleasant consequence if the design is exceeded.
There was a post a while ago, possibly referring to a Kitplanes article, about the most common cause of RV-4 wings parting company with the airplane. As I remember, it was pilots newly acquiring an RV-4, not builders, that would execute a fast low pass with a zooming pull-up. Easy to overstress any airplane. The RV series is very responsive without being twitchy but even SMALL stick inputs can results in LARGE changes in attitude. Pull the stick back half an inch at cruise and see how fast you are suddenly at another altitude.
Ya'll be careful out there now.....
I bet some would if it was lighter (like the 8), carbon fiber, stronger/stiffer in torsion and bending. Then counterweight factor could be better. Reno/racers might want it.
Can this be done in carbon?
I don’t think adding a new untested rudders into the mix without it going through Vans engineering would satisfy my worries if I had a -7. Changing stiffness and mass will change the aeroelastic axis and with out proper engineering may actually reduce flutter margin.
Although the RV-10 and -14 rudders still have riveted trailing edges, the internal structure is different from that in the-7/9. Stiffeners are tied to the rudder spar with shear clips, and the stiffeners themselves are much more robust - the horizontal flanges are joined to their mates on the opposite side with a rivet about halfway down the rudder chord. Also, the counterweight skin is integral to the rudder skin and not riveted on as with the -7/9.I have been considering, with some apprehension, getting some instruction/introduction to some gentlemanly aerobatics in my recently completed 14A.
Posts like this worry me. The point of the counterbalance is to balance the rudder, just like the elevators.Are builders actually balancing the counterbalanced rudders?
Nor is mine. But it's a different design, with different size and shape and different speed limitations on the airframe. Van did switch to a counterbalanced rudder on the -6 before they stopped selling the kit, as part of the development of the -7. A number of -6's have been upgraded to that tail, or the -8 tail, to get increased rudder authority.My original -6 rudder wasn't balanced at all.
I hit a burble at 130kts (straight and level) and the tail seemed to shake like a wet dog. Nothing like this has happened in 250 hrs since. It would make me happy if there was a full ground vibration test performed, but that is out of my control.
So how much heavier is a 8 rudder as compared to a 7/9 rudder?
EDIT > One question I have about aerobatics, and instruction in aerobatics is "Are parachutes required?". You can't or it isn't a recommended procedure to eject the canopy in-flight in an RV-14A, so what does a parachute do for you if they are required?
Put my feet on the rudder pedals (I usually fly feet off until maneuvering) , chopped power, and the vibration ceased.
Thanks Brian, I have just been lazy and not installed my 8 (aka 7 Short) rudder, and will have to invest in painting it too. I did all the glass fitting but not the final ready-to-paint details. Di you find any significant changes to landings?
More likely to have bad things happen with "stick free" (in this case rudder pedals free) than with "stick fixed". Control cables/tubes provide another constraint when held with control pressure.
The 7 Short (aka 8) rudder is smaller, lighter, and CG closer to the pivot than the 7Tall/9 rudder.
Area and weights not including fiberglass. Area is from spar rivet line aft.
Interesting that the 8 rudder CB weight is 1.85lbs vs the 7 rudder is 1.43lbs
Plans for the -7 big rudder (RV-9) call for the E-612-020 weight. Which according to Van's weighs in at 1.85lbs.
Would it be as simple as producing a skin that folds at the edge rather than being riveted? How about a piece of .062 or even thinner bent to scab on over the trailing edge?
edit: confirmed the 7 tall-9 has the E-614-020 (1.85#) called out.
From the manufacturing perspective, a folded rudder will cost more material since less number of rudder skin can be cut from a larger sheet of raw stock because of the odd shape. For a zip leading edge, more smaller rudder skins, left and right skins are identical, can be stamped from a larger sheet, thus, more economical use of the raw stock. We all love the low prices of Vans aluminum parts.
The Polen Special is derived form the Midget Mustang I which was designed by a Pier Engineer in the 40's. The Polen flew successfully for many years and then developed rudder flutter. The fix was a carbon fiber rudder.
Years ago I met a Harmon Rocket builder/pilot who bragged about flying at 300 indicated. It would seem that if the -7 does have a rudder problem the first thing to consider would be the construction and balance of the rocket rudder.
Again apples to oranges but since the starting point for the Harmon Rocket is RV4 parts, maybe John Harmon and other HR builders know things that would be applicable to the RV7.
Could you help the flutter-ignorant engineers with some understanding please. I thought that decreasing mass, moment, and increasing stiffness of a flight control would always extend the flutter speed. Given fixed design otherwise.
I do understand the aft fuse, HS, VS structures are all involved the dynamics, and one time at low altitude I hit a burble at 130kts (straight and level) and the tail seemed to shake like a wet dog. Nothing like this has happened in 250 hrs since. It would make me happy if there was a full ground vibration test performed, but that is out of my control.
