https://goo.gl/photos/PgSbrtM3zGN4ZcYa9
So is this the best I can do for picture hosting for less than $400 a year?
Kentlik I have had good luck with Flickr lately. Unfortunately it won't help with the older photos unless you redo them all.![]()
I'm on the free plan. Do they still offer that?
No go on them there pics good buddy. Dang photo hosting sites
Hopefully your aware that all your photos from post #107 and earlier are not showing up and many of your photos after post #107 are missing.
Very interesting build otherwise.
Tinypic still works well for posting pictures
Pics aren't showing up again Kent. Just seeing a circle with a dash through it.
Just to let you know, I'm not seeing the pics.
Kent, where do you post your pics from? I know sometimes it is a matter of them not being set to public. Flickr has worked well for me if your in the free market.
Kent: I'm a couple years into a 9A rebuild project. Mine was damaged in a nose over at fairly low speed. Since you are not building the kit in the normal sequence you will find yourself having to jump around in the build manual and at times get creative accomplishing tasks that aren't in the usual build. Feel free to contact me.
Don Broussard A&P, IA
RV9 Rebuild in Progress
I see post 135 and 136, Post 137 is a reply from Merrill Evans.
-Marc
I have found this to be the case for the entirety of the rebuild. At times I get lost trying to figure out what to do next and have to spend copious amounts of time in the manual getting on track.
Just thought I would let you know you were correct!![]()
You are making really good progress and are doing high-quality work. Sometimes when you get to the ?what to do next question? you just have to pick something that needs doing and press on assuming it all needs to get done sooner or later. I?m about at the 80% point and so far have not painted myself into a corner. My reality is that I?m too busy to work on mine very often.
Don Broussard
57 Pacer
