Mike S
Senior Curmudgeon
toothed wheel
OK, gotta ask---------is the toothed wheel a one off item, or something commercially available for purchase?
Is there any reason the pickups cant be mounted at the case split line, thus removing all the heavy bar stock used to offset the pickups. Of course if the pickups are mounted at case center, the skip tooth must be offset to compensate.
Considering all the stuff in the prior pages about the drive speed of a six cyl mag/rotor assembly, I suspect your mag hole trigger may not be a viable option for me???
As I read these, your setup is actually running twice the need RPM at the pickup--------and most likely wasting a spark in the exhaust stroke??
