Keep VAF
Going
01-09-2006, 11:10 AM
Show us your panel!
I haven't seen a panel thread for 8's, so I thought I'd kick 'er off!
Here's my front panel so far; in a few weeks I should be able to update this with a lit picture. Hopefully, only the intended components will produce light... The blank area on the right side is my 'play area' - it's removable, and empty right now - ready for expansion. I'll update my post with knee and arm panels, too - right now I'm adding to them lots of buttons, valves, lights, and things that go beep.
What do your front, knee, arm, and miscellaneous panels look like?
01-24-2006, 02:14 AM
Panel
Here is my panel:
Garmin GNS-430, GTX-327
Grabd Rapids Dual EFIS and EIS-4000
TruTrak Digiflight IIVSG
It all works and each item communicates properly...in the garage
Cheers
FM
01-24-2006, 02:27 AM
FM's second try on the panel
Here is the link
01-24-2006, 06:47 AM
Panels
You guys are really doing some great work on your panels. Here's Paul Dye's, in case you have not seen it:
Click on the picture for more details.
01-24-2006, 07:03 AM
Not as much glass but...
Jeff Gross
N250JG RV-8A (#81185)
"Object of Desire"
Amarillo, TX
Reason: new domain
01-24-2006, 07:33 AM
VAF Moderator / Line Boy
Now Jeff, you're going to continue the stereotype of southerners who work (and fly?) barefooted....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
01-24-2006, 05:33 PM
Larry Bowen, RV-8A
Reason: URL update
01-25-2006, 04:57 AM
Larry,
I really like the shade of gray you used on your panel. What paint did you use?
Dave
Dave Setser
CFII/MEI
EAA Technical Counselor/Flight Advisor
RV-7 N701ED Flying!
Nashua, NH (KASH) / Plymouth, NH (1P1)
01-25-2006, 07:10 AM
Paint Scheme
Larry - I couldn't find a graphic of your paint scheme on your website. Do you have it up yet, or are you waiting for the baby to come out of the paint shop? BTW, you really made the upper gear intersection fairings sound easy!
01-25-2006, 08:03 AM
barefoot'n it
But Paul, when I moved down here I just remembered that saying "When in the south, do as the...." oh wait, wrong one.
Actually I do usually fly barefoot, most of my shoes are too wide and get stuck between the flanges of the rudder pedals. Darn fat feet!
Jeff Gross
"Object of Desire"
Amarillo, TX
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
