Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
08-04-2022, 08:55 PM
unfluencer
Non-engineer rudder idea for OSH gust events
Entrepreneurship / Marketing major chiming in…..be gentle.
Please don’t call me an idiot too fast, but if you could connect two pieces of angled aluminum with a full length hinge, pad the inside surfaces, place that along the entire trailing edge length of the rudder, then hold that in place with bungee type cords running to the outboard ends of the HS.
Three or four small C-clamps gingerly holding the hinged contraption in place.
In a wind event, wouldn’t this apply the same tension along the entire length of the rudder?
Silly drawing below, note the bungee that runs in FRONT of the VS for stability.
A sort of ‘last resort’ OSH thing, not a use-all-the-time type thing.
Apologies in advance if this type thing has been discussed before ….. I haven’t seen anything that applies pressure along the entire trailing edge length of the rudder. That’s what I’m trying to address here
Shields up…crawling under the porch.
V/r,dr
Doug Reeves (your host)- Full time: VansAirForce.net since '07 (started it in '96).
- Available as Contract Pilot (ATP. PIC typed in G-V(450/550) and Phenom 300). Flying resume.
- Part time: G450/550 and Phenom 300 seat support at CAE (KDFW).
08-04-2022, 10:07 PM
I think that’s probably what it would take to prevent the kind of damage we saw (basically even with gust lock, the rudders were “twisted” if the lock held, and just bashed to pieces if it failed).
But, I am wondering if instead of all that effort, how hard would it be to, at events like this where you know you aren’t gonna fly again for a few days, AND we knew a storm was coming several hours in advance, to just remove the rudder altogether and stow it in the cabin, put it back on in the morning. If you made your tail light with a plug, it’s only like 3 bolts right?
Just another idea…
08-05-2022, 12:51 AM
We use a simple rig called a whiffletree or Whippeltree to even distribute loads across a structure in the structural test lab. I believe that such a rig could be made from aluminum tubing or angle and some small diameter cable or low stretch line and i stalled on either side of the rudder trailing edge and anchored to the horizontal stabilizer tips or hinge points as others have done.
https://en.m.wikipedia.org/wiki/Whippletree_(mechanism)
An alternative would be a rig made from line similar to the line groups used in rigging square parachutes and paraglider canopies. Lightweight, compact, and inexpensive.
https://en.m.wikipedia.org/wiki/Paragliding#Wing
- larosta
08-05-2022, 07:02 AM
Secure the rudder hard over to the rudder stop instead.
08-05-2022, 07:52 AM
I think the trick is to have something that would simulate what you would do with your hands if you were holding the control surface during the storm.
You would probably let it move a little, and as it got closer to the stops, you would push harder.
If you were working the rudder pedals to hold it in place, you would do the same - allow it to move a bit, but push harder as you get close to the stops to avoid a slam.
Something like the anti-splat ultimate gust lock, but with hydraulic dampeners and springs to allow some movement, but not allow the control surface to hit the stops hard.
08-05-2022, 08:04 AM
Maybe stupid
This may sound stupid but how hard would it be to just take off the rudder for the week? P.S. I'm not a builder
08-05-2022, 08:29 AM
Digging a little deeper.
What would be the tension on a rudder cable with a 90 ft-lb torque? 360#? The Gustbuster guy calculated 90lb for the tall 7/9 rudder is that in the ball park?
What torque on the rudder horn is acceptable? Is it the same for an 8 (.020 skin), 7/9, 14? That is three are different designs.
To the OP . . . Gotta say, the idea of something covering maybe 18" of the TE might me enough to carry the loads with a single cord. A bungee with rope stop backup on both sides. Structure to transfer the loads to the elevator safely also are a potential factor. We need something easy to install, carry the loads, and be easily stowed. If the 7/9 rudder was restrained just above the HS then we have about 20" from the pivot making about 50 lbs to restrain. 18" of TE contact gives 3 lb/in if that means anything.
My mind keeps slipping into Vans design world for the answers.
I'll bet some Vans engineers are talking about this already. 80% chance (opinion) they will develop a recommendation as a result of all this.
Bill
RV-7
08-05-2022, 08:56 AM
I ordered a couple of Steve Melton's gust locks for the rudder as backup for my Anti-splat gust lock. As in the OP, it seems reasonable to support the rudder at at least one other point along the trailing edge in more extreme conditions rather than just relying on pinning the horn or blocking the pedals.
RV-9A, 2011, bought flying
IO-320D1A (factory new), C/S
Dual Pmags
IFR equipped
AFS 5400/3500, G5, IFD440 navigator,
bunch of other stuff
08-05-2022, 09:29 AM
Steve made a nice silent video and he installed the elevator lock in 30 seconds. One side was rope only, the other contained a bungee with a short rope loop, just enough for installation.
Bill
RV-7
08-05-2022, 10:45 AM
Torque
As I read through the threads, it seems that twisting torque along the trailing edge from a fixed end and a free end caused the damage. And when a midpoint was used, the lever arm was greatly reduced and there was less potential for damage.
Which leads me to believe that if the rudder horn was secured and a gust lock at the opposite end of the trailing edge (rudder top), the rudder would have a much better chance of survival due to reducing twisting torque.
Which says to me that a high & low gust locks are the way to go.
Webb Willmott
Jackson, MS
RV8 - Current Build
V35B - Flying
RV7A - N32WW (Sold)
Reason: Verbiage
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
