Retooferab
Member
Has anyone put a yaw damper on and RV8?
Asked about this also. I’d like to put one on my 7, but haven’t found a good way to install yetHas anyone put a yaw damper on and RV8?
I would think the -8 and -10 both being a two row longer fuselage would benefit similarly from a yaw damper. Having flown in neither, I have no way of knowing what the back seat experience is like. I’m curious why many say the same thing about the -8 not benefiting from a yaw damper.Have one on my -10 but not my -8. Not necessary on -8.
Many airframe manufacturers recommend autopilot off in severe turbulence - so it doesn’t inadvertently over-stress the airframe. Something to consider.I know in some very rough weather days with severe turbulence to where I need to cruise at 95 knots it would definitely help.
Haven’t installed a Yaw servo, but would love to see how someone did. Retrofit sounds like a non-starter, but just bought an RV-8 with the Garmin autopilot. Wouldn’t thought it needs one, but after flying it home yesterday for St. Louis across the Rockies in the afternoon thermals…would babe nice. Didn’t have anyone in the back seat, but would be cleaning barf for a week I had. It was bad enough in the front seat.Has anyone put a yaw damper on and RV8?
The install for a 14 and 10 is already pretty well documented for a GSA 28. The yaw damper is not meant to supplement your feet (At least not until in cruise in clear weather) but assist when Florida thermals and side gusts push the vertical stab one way or the other. Even though both occupants in a 14 sit over the spar my wife (And sometimes myself) can tell immediately if I have the yaw damper off. It reacts much faster than it takes me to recognize the side gust and press on the appropriate rudder pedal. It can be tested on the ground by simply pushing on the vertical stab and watch the rudder react immediately to the deviation. Wouldn't want to leave home without it.Haven’t installed a Yaw servo, but would love to see how someone did. Retrofit sounds like a non-starter, but just bought an RV-8 with the Garmin autopilot. Wouldn’t thought it needs one, but after flying it home yesterday for St. Louis across the Rockies in the afternoon thermals…would babe nice. Didn’t have anyone in the back seat, but would be cleaning barf for a week I had. It was bad enough in the front seat.
If anyone has retrofit a GSA 28 servo for yaw, please check in.
I didn't know about this trick. I was flying today over the Socal mountains in the late afternoon and it was turbulent from all the thermals poping off. The tail on my -8 was doing some little dances but when I put my feet on the pedals, the little wagging mostly went away. I still got plenty of vertical jolts though.I wont say that you should rule out a yaw damper (I don’t know anyone that has one in an -8)….but most of us find that the airplane calms down considerably in turbulence if you just put your feet on the rudder pedals - that keeps the rudder from wagging, and effectively doubles the size of the vertical fin. Try that before you think of a more complicated option….
Will try the foot thing next time. 8 hours of flying in it is prob not the normal mission, so will fly a bit and try this pedal method
AgreeI tried the feet on rudder pedals for multiple flights this past week and after 15 hours of summer turbulence in cruise determined that it is a negligible benefit, if any. It still wags and is nothing like an actual yaw damper.
I wonder how the yaw damping is different to your RV8A versus a tailwheel version. My RV8 has two springs connected to the rudder, and the rear wheel probably added to the minor surface area to add to the damping compare to the nosewheel version. Interesting observation though.I tried the feet on rudder pedals for multiple flights this past week and after 15 hours of summer turbulence in cruise determined that it is a negligible benefit, if any. It still wags and is nothing like an actual yaw damper.
Yes our A’s only have the rudder pedals connected to steel wire running to the rudder with no springs.I wonder how the yaw damping is different to your RV8A versus a tailwheel version. My RV8 has two springs connected to the rudder, and the rear wheel probably added to the minor surface area to add to the damping compare to the nosewheel version. Interesting observation though.
I may have heard of that as wellOn the 14 it does a great job of settling down the airplane in turbulance.
Also, if you leave it on accidentally while landing you'll get an immediate holy shit moment thinking your rudder is locked up, so I've heard![]()
If left on does fight you a little but nothing a little pressure can't overcome. Just don't crank up the torque beyond your leg pressure !On the 14 it does a great job of settling down the airplane in turbulance.
I’m thinking about it but see that the rudder cables seem to be spaced further apart from what I can tell. That will require a different one off bridle. I haven’t investigated beyond that because I don’t have Skyview yet.Would following the RV-14 diagram for the install work for us in the RV-8? It seems like it would.. we have the same cables, in more or less the same place. Has anyone done it?
