I'm mapping out all the wiring runs, and am unsure that the four holes in the main spar get the job done.
One will be for the aft battery cable, and maybe a few smaller ones with it.
I have static, pitot, and AOA 1/4 tubing to run forward.
There are two com antenna cables, plus one GPS, and one transponder.
Then all the usual other cables for lighting and everything.
Anyone with a full load of tubes and cables run into trouble at the main spar?
There are holes under the armrests on each side that go aft. What have they been used for? Are the wires there conspicuous? - they aren't covered by panels fully.
A lot of the old threads have lost their pictures with time and the VAF upgrade.
