Wiring runs, and main spar
JDA_BTR
I'm mapping out all the wiring runs, and am unsure that the four holes in the main spar get the job done.
One will be for the aft battery cable, and maybe a few smaller ones with it.
I have static, pitot, and AOA 1/4 tubing to run forward.
There are two com antenna cables, plus one GPS, and one transponder.
Then all the usual other cables for lighting and everything.
Anyone with a full load of tubes and cables run into trouble at the main spar?
There are holes under the armrests on each side that go aft. What have they been used for? Are the wires there conspicuous? - they aren't covered by panels fully.
A lot of the old threads have lost their pictures with time and the VAF upgrade.
The largest connector that went through these spar holes are the RG400 connectors for the transponder, comm antenna, and ADSB transmitter antenna. I also route the various lighting cables, servo cables, etc through these holes. Depending on how you dress and ziptie the wire bundles, they can be inconspicuous from the pilot perspective. I also find out the more inconspicuous you make them, they will be more difficult to route in order to make them hidden.
I think I went through 3 different configurations before I call it done, mostly from fatigue rather than perfect. Most of the wires are small but just make sure you make allowance for the RG400 connectors.
Aft mounted dual batteries here grounded locally. Power wires ran through mid longerons. Everything else thought the floor. All my spar pass throughs are full. Pitot & static under and across floor. Power wires can be seen on both sides at the transition from center to forward section.
Good luck!
I’m running all those wires in our Rocket project right now - basically the same thing, except that the wing spars go all the way to the center, so we don;t have grommet holes in the spar web.
Nevertheless, as my RV-8 has aged, the spots under the canopy rails have proven to be excellent for adding wires. Put the in wire loom material or snakeskin, use some good wire-tie attachments, and no one will ever know they aren’t supposed to be that way.
I'll be terminating the antenna wires after I route the cable so this is less of a concern for me.
Good luck!
This is very good work in the photos. I'd love to see all the interior pics you have. Imitation is the sincerest form of flattery.
Don't run your Pitot and static lines through the Main Spar. That will create a low point which could possibly end up trapping water. Run those lines just below the main longeron.
My battery cable, static lines, headset jack wires and rear seat GPS wires run through the armrest areas on my 8. Not too conspicuous after arm rests are upholstered.
I don’t know if
not bad advice on the static. The pitot and AOA start low and can’t be run without something of a loop. On the left side the best route to the panel seems to be behind the throttle quadrant but a new hole would have to be opened up to get from aft past the rear spar there. I’ll think on it.
I've looked a lot for pictures of static/pitot/AOA lines run forward from the wing roots on RV8's and I just can't find something that makes sense to me. No matter what I do, I end up having to add holes in places and I'm uncertain about where is okay and where is not. I won't put new holes in the spar, so that's out.
Could someone post some pics or links showing their pitot/AOA lines routing forward? If I decide to put the ADAHRS aft I'll still need to run the static and pitot forward for my G5.
GSU25 mounted on right side of instrument sub panel with stiffener plate, works fine no vibes. Rans pitot/aoa down right gear tower and thought the floor in pic. No water collection issues at 160 hours. Had to drill two holes in floor ribs for pass through. Statistic runs through bulkheads under cockpit rail.
Would you be able to show me pics of your tubing run from the floor to behind the panel or did you run it through one of the right spar 3/4 holes?
I don't have a pic but yes through spar hole the into acees hole at bottom of gear tower then straight up to the GSU.
