Edited for NOT go through. He said on one end of the doubler holes matched, but the other end did not match. Not clear if it is progressively offset along the length. I suggested using a drill bit solid end to roughly quantify the offset. The second spar was just fine. L/R not specified.Would go through…… or wouldn’t go through?
I checked my spars, and I have the same problem. It almost seems to me that the doubler didn't have clecos on one side during riveting. The misalignment on one of my spars is small, and I can pry the holes with some difficulty to be able to put LP4-3 rivets in them. But the misalignment on the second spar is much bigger and I can't pry it into place. The holes seem to be the correct diameter though.I just checked both of my spars. I can't get an LP4-3 rivet through any of the holes where the doubler is installed. On the shorter piece of the spar, it looks like the holes are visibly smaller than a regular size 30 hole. I can get a size #30 drill bit through the longer spar piece, but the shorter piece(the one with the doubler), I have to step down to a #31 drill bit to get through. I'm calling Van's in the morning, but has anyone reamed the spar to get rivets installed on the -15? If nobody else has done this, I don't plan on being the first.
I consider reaming holes to be acceptable when the fastener will be a standard aluminum rivet because it does a fairly good job of entirely filling an irregular shaped hole.To answer questions about whether anyone has reamed the rivet holes on these 15 spars: Yes I have.
This is the 8th RV I have built. There have always been instances on every one when I had to ream a rivet hole to get a rivet to fit. What exactly does anyone think will happen to those rivet holes if you do have to ream them to get a rivet to fit? You should absolutely get advice from Vans on this concern, but I pretty much know what they will say.
Seems pretty clear in the KAI…I'm not sure exactly where you are describing but the KAI's do call for reaming some holes during the skin riveting process. Step # 2 below.
Nothing yet. I've pinged them once already.Any replies back from Vans on this issue?
Sorry, I had been excommunicated from VAF and only recently reinstated. I posted a lot more detail on the RV-15 forum of FB, but I'll summarize here.Any replies back from Vans on this issue?
The good news is we both caught this before assembling a majority of the wing.I'm another -15 builder with the same hole misalign issue who reported the issue last week with detailed videos who is still waiting for a response.
The misalignment on my spar absolutely would.Is the misalignment enough to prevent clecoes from going in?
Maybe both. But irrespective of that, the spar is unacceptable as built. I’m not willing to drill out a row of -4 rivets that pass through the spar web and replace the doubler. Van’s can do that at the factory with their equipment and experience assembling these spars. It’s probably a $3000 or greater part and I’m not taking the risk of messing up the spar to fix an obvious assembly error.I don't remember if it was said but does a tapered shank flex the holes back towards alignment any? The question being are the holes mispunched or is the part not laying flat against the spar web?
Look at my photo above. While there could be multiple issues, my spar milslignment were all a shear due to the over bent spar cap. IMO it is not caused by miss placed holes along the length, the offset is due to the bending angles, but Vans must validate that first. It is more than just replacing a part. I thought about using a porta power (or other methods) to bend the spar cap back into alignment (no wedge air gap) but have better things to do when Vans can do them better and faster. Right now, it is "their" spar.I don't remember if it was said but does a tapered shank flex the holes back towards alignment any? The question being are the holes mispunched or is the part not laying flat against the spar web?
Tom, I can say with certainty that I did not have this problem with my alignment, and I doubt that you did either. It seems to be something that happened with spars that were sent much more recently and is certainly unfortunate.Is the misalignment enough to prevent clecoes from going in?
I did not notice anything on my L wing (now complete); the clecoes for those aft holes were a bit tighter, but my assumption was that was due to them not being reamed. The reaming was uneventful, and similar across all of the holes (i.e. there weren't some that required excessive reaming).
Wow. I’d be beyond upset.I arrived at vans with my thrice confirmed and delayed will call date of june 25 at 8am, then was told my kits woul8dn't be ready that morning. But after a half hour of scrambling they came up with my kits minus one main spar, horizontal and elevator. Was told the spars were back ordered again due to anodizing issues... wondering if it's something to due with this misalignment issue.
We had a slightly different take on that saying at a large airframe manufacturer in the PNW: "There is never time to do it right the first time, but there is plenty of time to do it over and over again!” This is waste and costs mucho dinero’s.At my previous employer (Lockheed) we frequently said “we aren’t given the time to do it right, so we then have to find the time to do it over”. Seems a bit appropriate here as well.
Way off topic, but Alan Mulally was one of those once in a lifetime people. The 777 program was an incredible success, in no small part due to his leadership. When he left Boeing, I was terribly disappointed. The 787 was a disaster as you indicated. (Boeing was my first employer out of college.)We had a slightly different take on that saying at a large airframe manufacturer in the PNW: "There is never time to do it right the first time, but there is plenty of time to do it over and over again!” This is waste and costs mucho dinero’s.
Early during the original 777 program, Alan Mulally called us folks working on the Program to a meeting in the factory. Three large dump trucks drove in and dumped a huge amount of scrapped parts on the floor - all waste from previous programs. He recognized that design changes (for whatever reason) and correcting errors was very costly due to waste. So he gave extra time up front during the design process (e.g., longer Loads & Design cycles, production planning and processes) to give us a better chance of getting it right the first time. Getting it right the first time was not always possible, but it cut down the amount of rework substantially. It paid off handsomely on that program with much less rework than previous programs. And the customers were happy because they got a service-ready airplane at delivery. Of course the dullards from MacDac, that bought out Boeing with its own money, threw all those lessons away on the 787 Program and later ones, and the rest is history.
Van’s seems to have rushed out the -15.
I was mistaken about receiving the spars, I did receive them at will call. Was a subkit that was backordered.... I had the part numbers confused, my bad for saying that.Wow. I’d be beyond upset.
I also have heard nothing back from them for a solution. I sent pictures of everything they wanted 12 days ago. I pinged them 9 days ago. No response.Sorry to hear that. Glad you checked before building the wings!
I wonder how may of these defective spars are out there? Quick QC check at Van's would have saved them a bunch of money and some customers a lot of aggravation.
I reported this on 6/22 and heard back from Ciaran very quickly. Clarissa was supposed to get with me on arrangements for a replacement plus return of the defective spar. Crickets so far. And yes, I know OSH is a few weeks away. Hopefully you'll have a better response.
Disappointing, but I can’t say I’m surprised.I also have heard nothing back from them for a solution. I sent pictures of everything they wanted 12 days ago. I pinged them 9 days ago. No response.
Not an acceptable answer from Van’s. Clecos are not going to correct this misalignment.I just called them today about this, Vans is saying put clecos in every third hole and they should line up. Some of the holes in mine are so far off I can't even get clecos to go in.
I agreeNot an acceptable answer from Van’s. Clecos are not going to correct this misalignment.
I’m still waiting to hear from Clarissa when they are shipping my replacement spar.
Were both of yours messed up? Mine was just the right oneNot an acceptable answer from Van’s. Clecos are not going to correct this misalignment.
No only one. Whichever one is part number -002. I didn't bother to look which side it's for.Were both of yours messed up? Mine was just the right one
Exactly, which is why I’m not going to do it. Van’s is welcome to try it when they get my defective spar back.I feel for you guys, that sucks ... and as pointed out before, drilling out and replacing that would be a real chore, not easy to do without damaging the spar
As someone who works in manufacturing, I have a lot more forgiveness for out-of spec parts. Not that they are acceptable, but 100% exaustive inspection is frightfully expensive. Unless we want to pay LockMart prices for RV parts, we have to accept the possibility of mismade parts and that we are the final inspector for our work and it is up to us to find any defective parts. It is also Van's responsibility to replace or reengineer those parts or the assembly to correct the problem, but that doesn't happen instantly.Exactly, which is why I’m not going to do it. Van’s is welcome to try it when they get my defective spar back.
I think those of us with the misaligned holes were the lucky ones who were caught up in the defective anodizing process and then Van’s rushed to catch up. Whatever QC they might have done was probably just bypassed, as anyone with any experience would have caught this in a few minutes of even a cursory inspection.
I'm going to disagree with you a bit here. This isn't a $10 rib. I'd be willing to bet this is the most expensive single part (certainly in the wing kit) and possibly in the entire RV-15 kit. These parts were already delayed at least once due to defective anodizing at a supplier. I found the defect within 2 minutes of inspection and I'm not an experienced nor trained eye. The person assembling this spar could have and should have caught the error. Even at $100 per hour fully loaded for an employee - a quick inspection would have saved Van's at lot of money.As someone who works in manufacturing, I have a lot more forgiveness for out-of spec parts. Not that they are acceptable, but 100% exaustive inspection is frightfully expensive. Unless we want to pay LockMart prices for RV parts, we have to accept the possibility of mismade parts and that we are the final inspector for our work and it is up to us to find any defective parts. It is also Van's responsibility to replace or reengineer those parts or the assembly to correct the problem, but that doesn't happen instantly.
I just have to ask, but isn’t this something THEY should be doing when they build it?I just called them today about this, Vans is saying put clecos in every third hole and they should line up. Some of the holes in mine are so far off I can't even get clecos to go in.
Awesome, I am hoping to hear something back soonTurns out the spar is $3800. And some wonder why I wasn't willing to drill out the doubler myself.
Good news is a replacement has been shipped. Hope the others with this issue get their replacements soon.
