I tried some and had poor performance. I actually had a precautionary landing to replace them on a trip because of gaps closing on several.Why do we need adapters when using non-aviation plugs? Are there no 18mm plugs available in the proper heat range? Are the 18mm plugs simply more expensive?
Unfortunately, there is not a wide selection of reaches, resistor and heat ranges. Some are happy with the Autolights, some not.Why do we need adapters when using non-aviation plugs? Are there no 18mm plugs available in the proper heat range? Are the 18mm plugs simply more expensive?
I'm guessing these are the Autolite 386. These are a bit hotter than optimal for most, and "I think" the ONLY 18mm resistor plug available today.t’s a good question….I recently bought a set of AutoLite automotive plugs that were recommended here, for my NOS Electro Air electronic ignition system. They weren’t in stock at NAPA but arrived the next day and were cheap. 18mm
Yes. I figured they aren't very common. I think I saw some tractor motors use 18mm.I assume you are asking about 18mm non-aviation plugs?
Well...
a) you aren't going to find them in the local auto parts store when you need one on some cross-country
b) I can't think of the last time I saw an 18mm automotive plug. 1936 International pickup truck, maybe?
My x-340 was built with 14mm plug holes. When I recently had to replace a couple cylinders, the new cylinders I installed were 18mm. So, I have 4 spark plug adapters currently.When Mattituck was building my engine, they asked if I wanted 18mm or 14mm spark plug holes. I specified 18mm even though I knew I would be using an ignition that supported auto plugs. This was a mistake, but I didn't know at the time, obviously.
As others have said, the selection of 18mm plugs is very limited.
They are the 386s. There was a second plug that was suggested as well but I never checked availability because I wanted a hotter plug anyway.I'm guessing these are the Autolite 386. These are a bit hotter than optimal for most, and "I think" the ONLY 18mm resistor plug available today.
I’m considering running a test set in one side to see how they hold up in my application. Curious what configuration or use case you have that makes a hotter plug more desirable?They are the 386s. There was a second plug that was suggested as well but I never checked availability because I wanted a hotter plug anyway.
That is probably the only benefit to hot plugs. All other use cases (sustained high power, Lean, ignition advance, leaded fuel, and a host of others) are made worse with hot plugs. Once your oiling clears up, keep a close eye on things!I have newly OH’d chrome cylinders and am still pushing oil past the rings and there is a slight tendency to foul the lower plugs.
While the instructions from the MFR should be given due consideration, there is a lot of things to question in this statement. For example, does the physical size of the hex wrenching surface define the operating characteristics of the plug? Probably not. If I had to guess, the fact that there is almost no selection of RESISTOR 18mm plugs drove someone to a NON resistor unit and that scrambled the brains of the Pmag (I’ve been there, done that). That OR a user used a Autolte 386, and had jumpers out in an edge case engine, hot day, and suffered pre ignition due to the hotter than optimal heat range of that particular plug., we have at least two reports from customers who tried 18mm thread plugs – with very poor (near disastrous) results
Here's quite a large selection of 18mm plugs. No idea if any are appropriate for our engines. There are lot more there than I would have guessed. Mostly for tractors and "classic" engines.Unfortunately, some of us are like children and don’t like to be told “no” without a good reason - often at our own peril (guilty as charged).
Same here. Autolite 386 plugs for couple hundred hours with no issues.I have been using the Autolite 386 plugs in two planes (RV4 and Glasair both with Lycoming 360s) for nearly two thousand hours. They have performed flawlessly. They are available from all four of the auto part store chains near me and all are under $3 each. The nice part of that is my "plug cleaner" doubles as my shop waste bin. To test longevity I ran one set until I got an intermittent miss which occurred at 317 hours. I change them at 100 hours since you can do all eight for less than $20. I have several friends running these plugs as well. I really like not having plug adapters. Just one testimonial but I am very pleased with these 18mm plugs.
Plenty of 18mm plugs. Once you narrow those down to "resistor" the list gets smaller. Narrow it down again to the compatible heat range and seat type, the list gets VERY small.Here's quite a large selection of 18mm plugs
I understand they sell them, but would you honestly think that’s a motivator? You’d be better off adding the cost of adapter to the magneto.
True, I'm just pointing out that over $100 for 4 small pieces of brass alloy is not insignificant. Paint me in the camp I want to see more info as to why they don't recommend 18mm.I understand they sell them, but would you honestly think that’s a motivator? You’d be better off adding the cost of adapter to the magneto.
It’s not a nickel and dime operation like an airline ticket where bags are extra, leg room extra, board early extra etc etc. it’s not a marketing scheme for the ignorant.True, I'm just pointing out that over $100 for 4 small pieces of brass alloy is not insignificant. Paint me in the camp I want to see more info as to why they don't recommend 18mm.
We covered that. 18mm plugs are not widely used any longer. Anywhere. There is a VERY limited availability of 18MM plugs that will even physically fit an aircraft head, less that are resistor, and NONE that actually meet the heat range we need.It seems obvious that no adapter would be superior but there must be a reason why the smaller size with an adapter is used...
Check out the link below for some basics:Please educate me.
What are heat ranges and why do we care so much when running 100LL, lean mixtures, etc?
If you look through some other threads, you will find this topic discussed at length with different plug options. There are several people including the 386's with excellent results, but most 18mm plugs, including the 386's are on the hotter side. I've tried several different 18mm plugs. They work, but YMMV.Why do we need adapters when using non-aviation plugs? Are there no 18mm plugs available in the proper heat range? Are the 18mm plugs simply more expensive?
I've read of failures.Apart from the price, what is so bad about adapters??
Where and when?I've read of failures.
Where and when?
Ngk solid cap iridium plugs, 500+ hours, no fouling whatsoever.For those of you using 14 mm automotive plugs with adapters, same questions:
1) what plugs and gaps
2) do they foul more than aircraft plugs,?
3) any problems?
I sweat less when the big fan IS spinning.Keep the big fan up from spinning, you’ll sweat less.
I've been using what Lycoming sent with the engine:BGK #3691, no fouling, no issues, just works. I change them every 100 hrs because they are cheap.
This is what I do and Lightspeed engineering recomends to torque the adapter first at a slightly higher torque setting than what is specified for the plugs.The adapters have never come out when the plugs have been removed.
One cannot argue with success but this methods seems more prone to removing and installation issues than the set and forget method above.Handtight adapter onto plug, than plug with adapter and correct torque into cylinder.
Then I found Dan's comment - thanks again Dan. IO-390 requires a long reach setup:I've been using what Lycoming sent with the engine:
Denso #5647 long reach solid tip plugs.
So I have the long reach adapter.
To use the 3691 you must have the short reach adapter. Is there any performance difference between the short and long reach adapters? Any tradeoffs?
The 3691 is way - WAY cheaper. Cheaper enough that maybe I'll get the short reach adapters next spark plug change.
Why do we continue to bring up problems that were discussed decades ago? How bout doing a literature search first. I discussed this problem back in Sept, 2010.
Search for,
Dont waste your time with Autolite 386 plugs
I suppose there is enough information on the internet and the archives so you would never have to talk or interact with anybody.Why do we continue to bring up problems that were discussed decades ago? How bout saving yourself time and $ by doing a literature search first. I discussed this problem back in Sept, 2010.
This is only for planes with new electronic ignitions right? Those of us with dinosaur magnetos have keep using the $50 plugs?Because pilots are a notoriously cheap lot. At $50/plug for an REM40E vs $4/plug for an Autolite 386, you're saving almost $400 at a changeover. Even if you changed them at every annual, you'd be ahead in the long run. Kudos to those who are knowledgeable enough to chase down alternatives like this, even if they don't all work out.
