I currently fly out of a towered airport with instrument approaches.
I have been using the VASI on landings out of habit, but it seems to set me up for a touch down a ways down the runway.
So do y’all land on the numbers, or 1000’ down on the offical “ touchdown” point?
Two things: Touch Down & Speed:
VASI, Aim Point and Touchdown.
Small planes can and/or should land well before 1000 foot touchdown on long instrument runways (unless wake turbulence is isdue then land way long up wind side of runway). The VASI (say 4 bar) is for large Jets. You can fly 2 x Red OVER 2 x White. However transition to 3vRed Over White or 3 Red over Pink IR 4 RED over the fence.
Nothing wrong with landing 1000' down the runway on a 6000' runway, especially if you need to turn off a taxiway at far end.. However you need to also know how to land well before that if needed or desired.
I use VASI or PAPI but SWITCH TO Visual Aim Point, FIXED SPOT ON WIND-SCREEN THAT DOES NOT MOVE UP OR DOWN. THAT SPOT IS END OF RUNWAY OR JUST PAST END OF RUNWAY (no obstacle, day VFR). Night I fly VASI always.
AIM POINT IS NOT TOUCH DOWN POINT. Using end of runway as AIM, depending on speed and when you you go idle, roundout, flare may touch down 100 to 500 feet past end of runway. You do want to go to idle in ground effect not to float. IF YOU WANT TO FLY VASI DO IT. LAND LONG if runway is long. With that said learn to spot land "on the numbers".
SPEED and OTHER TRAFFIC and TOWER
Other traffic faster behind you? Tower wants XYZ? Fly your plane safely. If you agree to do it, then do it. (keep speed up, turn off first taxiway...). If you can't don't agree to do it. Say unable...
. Keep speed up as long as you can but if you want to be at 65kts full flap at 500 above touch down zone, do it. If you are slowing to 65kts at 5 or 10 miles out, not a good thing for traffic flow with a lot of other traffic, will may cause issues and delays.
You can fly a fast approach and land long. You can fly a min approach speed, Vso × 1.3 approach and land short, shorter roll out... However hard to fly fast approach and land short. ATC and Tower Personnel are NOT pilots l(some are). So don't let them fly your plane. Most know and respect limits of planes even if not a pilot, but don't assume they do.
You should be able to keep speed 130kts, up 4Nm out straight in, pattern altitude, then start to slow, configure fill flaps, then descend to runway, landing, youching down before 1000' from end of Rwy. Roll out another 500 to 1000 feet. If entering mid field down wind plan on being at Vfe abeam the numbers. I routinely turned off taxiway 800" feet from end of runway with some headwind, w/o leaning on brakes. If no wind, landing little long, few kts too fast 2000' turn off was easy. If you are not able to do that constantly, consider some training.
If you are having trouble slowing to flap extension speed, lower power earlier and more drastically AND, eith a short climb (100 feet gain) AND/OR slip you can bleed speed faster. Once at Vfe put flaps in as needed. If you need to come down all flags all at once, and lower nose.
VFR Cessna behind you will need to slow down. That is their problem. We all try to work together. Tower would tell you or following traffic to go around. Don't worry about it. Don't be a slow poke but don't fly faster than you are comfortable with. However you should practice alternate procedures, slips, low or idle power approach, steeper and shallower approaches, etc..
I assume your airport is busy, may be airline traffic or training, VFR or IFR students. You could try and fly a faster final and then slow later but don't do it unless you are comfortable. There are slips, going to idle earlier, non standard techniques. If you cross the fence faster it will take longer to touch down... There is nothing you can do is float until speed bleeds off.
The IFR final is typically 5 mile segment or more. If it's VFR conditions then first come first served. If it's low VFR conditions or IMC WX, IFR traffic will be priority. IFR traffic is going 90kts on final or faster. Most small panes fly 90kt Inst Approaches. Jets 120kts or more on IFR final segment. It is common for Jets to be told by approach keep speed up to the FAF... the point you start descent to runway.
Consider faster final approach at half flaps to help tower when some one is gaining on you. A Cessna should be able to slow to near 65 to 75kts.
Don't let Tower rush you or do what you are not comfortable with. However train at altitude away from airport with speed control, descent at different speeds, power and configuration (no part full flaps).. Practice full slips. S-turns. These may not be something you use on routine basis, but have it in you bag of tools. You may want to get some dual with a CFI with RV experience. I am a CFI-I-ME ATP. I do RV transition training. PM me if interested.
