The coolant temp (only) on my 912iS has been cycling. The cycle period is irregular but the amplitude is fixed, between about 152 and 240 F. Here's an example from one flight today. Oil temp (blue line) stays quite constant, as did EGT. Coolant is 1:1 Dexcool:water, OAT was 18 F. I'll attach a graph of the coolant and oil temp data.
Takeoff was about where the lines first cross on the left (10:03:37). Landing was where they diverge on the right (11:10:43), as the oil temp drops and the coolant temp rises since it is no longer circulating. Oil temp rise at about 10:15:49 was a climb to get above clouds.
What could cause this? Can the temp sensor, or its electrical connections, fail this way? Are there diagnostic tests I can make?
