Evan's is good stuff, but I wouldn't run it in an installation that already has known issues with higher running temps.
That's interesting since my understanding was that Evans was originally adopted for use in Rotax powered airplanes that did run on the hot side because of its higher boiling point compared to traditional coolant (provided more safety margin if you often run near the temp limit).
It has since been found to be of little value because the poorer heat dissipation performance eats up most all of the boiling point delta since it will automatically cause the coolant temp to be higher just by using it.
I believe this is the reason that Rotax no longer recommends it.
