I hesitated to post this till I confirmed.
7A. Standard main gear. Elastomeric Nose gear.
I bought three postage scales from the big company. They are branded with the swish. Rated to 600lbs ea.
First weigh, I was very meticulous. Airplane level. Scales Tared. Multiple numbers recorded. Pretty happy with the results, but they are internet scales so there was always a bit of doubt.
My hangar neighbor (aka rockitdoc) was a racer and has a set of race car scales. We discussed weighing and decided it should be done again. I'll explain why shortly.
Round two the aiplane was rolled up, checked for level and multiple numbers recorded. OMG! She gained weight. We talked about it. He is an engineer and even knew how much she would gain to the pound.
The problem was my initial weigh was done by lifting the airplane. I didn't know this was a thing. Google it. When the airplane is lowered on the scales, the sensors are under side load and read incorrectly. If you do it this way, use something slippery to allow the gear to relax.
So now I have a good weigh, but what about my scales? Others have borrowed them. I did warn them about this issue and made it clear they have to roll the plane on the scales. I still wondered if they were correct.
Round three, I performed another weigh yesterday. This time with my scales to validate them. I even rolled the airplane off and back on. All three scales went back to zero when the airplane was rolled off. Weight was within ounces of his racing scales.
I'll sleep better knowing someone else using the scales isn't flying with an inaccurate W&B.
It may or may not help to add something slippery. I used two sheets of 4mil plastic with oil between. The plastic sandwich was slipped between two of the shims on each scale.
Thanks to RockitDoc for his help, scales and insight.
