Vertical Power Install Issues?
Walt D
Active Member
Patron
Anyone trying to get the VPX box to accept the downloads from the on line planner tool? When I attempt to download my online configuration file, the VPX log shows a long list of error messages regarding an inability to find various files and directories. I have followed the install notes to the letter, with no luck. At this point, the box is useless to me, without some sort of meaningful communication from Astronics regarding this. I've noticed that there seems to be little, or no effort to keep up with the Windows updates, as one is continually warned that installing the software represents a security threat to your computer. Running Windows 10, stated as supported by Vertical Power / Astronics. Spent 6+hours on what should have been a 2 minute effort given the cost of the product. Hopefully, I'll get a meaningful response from the company, otherwise, at this point, if one is expecting to save time and money with this solution, you're better off with fuses and switches. Can't help but notice that there seems to be no meaningful software update since 2013. In this business, that's an eternity.
Help!
I just adjusted mine, did it right from the laptop, didn’t use any pre done files, so I guess I’m saying I did it manually, and it went quick.
Besides the WiFi issue which is well known the only other issue I have had is the Ethernet to USB converter. Had to use one made by TP-Link and not the Amazon brand Ethernet adapter. Installed or help install 4 VPX Pro systems to date, all worked well.
