Check the scales and re weight?
Yes I'm kidding but hey - 500lbs out of nothing? The IO-540 engine itself weighs just about that ~540lbs and with it the bird is supposed to weigh 1500. LS2 is comparable heavy, even if Vesta's package was 100lbs heavier we still are looking for 400lbs stuffed somewhere around CG. It's really a lot of weight. Unless you soundproofed it like passenger car and added full car upholstery - then the weight is reasonable.
I am starting to believe the "calibrated" scales that were used were not calibrated correctly. I was carrying out some weight to put in the baggage area , 53 lbs to be exact, and I just could not believe that my plane had almost ten more of these 53lb weights in it than Van's has. 53 lbs is heavy! My original guestimates for the engine was a 100 lbs heavier.
How did I come up with this? Simple some of moments.
It takes 250lbs on the tail to lift the nose wheel off the ground. The tail weight is 144 inches from the mains. The my nose wheel is 76" away from the mains. The weight on the nose wheel should be 476 lbs. Which is approx 118 more lbs than is on Tim Olson's nose wheel.
Now using simple math why is the weight that the IA found to be on the front wheel 59 lbs more? His weight calculation is 12% higher than using simple math. If you apply this error to his total weight for the plane the new weight is 1818 lbs!
Now I have to double check his weight and balance. If his error, if at all, is this bad he could have put us in a very dangerous situation.
Has anybody ever had such an error? I just can't find the error of my simple calculations.
