Im working on the elevators right now. Looking at the nut welded onto sheet metal (elevator trim cable anchor bracket WD-415) just seems cheep and possibly prone to failure. Also, the threads inside the nut seems like it might cause cable wear? Is this part good to go, or should I do something different with it. Also, are there any issues with the elevator and trim tab build I need to be aware of. Thanks.
