Toss it?
thiggins
I'm getting close to first start at my shop (Rotax ran it an hour at the factory).
Should I toss the factory oil filter or just keep it and put my oil in?
I will be purging the oil system of air next.
I would use the one that came on the engine but a new one is only a few bucks so replacing it may be worth the peace of mind.
Yeah.
I bought a few filters along with oil while at Lockwood, just for this reason.
Yeah, relatively cheap insurance.
I can't speak for Rotax however in most engine overhaul shops they install a new filter after the engine has been test-run as the filter check is part of the post-test inspections that are carried out prior to shipping the engine out the door.
As you suggested, for a start remove the filter and see whether it looks new or used. If its new you're away laughing. If its definitely used I would probably be inclined to use it for the first few hours and then replace it.
Follow up
I can confirm that they did install a new and dry looking oil filter.
However, it was so attached (dry) to the engine, I could not remove it without totally destroying it. There’s a nice new one on it now, with a lubed gasket, torqued as documented.
:confused:
