Torquing Landing Gear Bolts
NavyS3BNFO
When you have to torque your landing gear bolts 5 in-lbs at a time and the wife gets tired of holding the wrench. Anyone else come up with ingenious ways to torque your landing gear bolts solo?
I tape the box wrench at the bottom landing gear access hatch with Gorilla tape, and torque the nut from inside.
Beware: During phase 1, after 10 hours, I rechecked the torque inside the gear tower, everything was still in torque. Great so I thought. But, I FORGOT to remove the box wrench because when I checked the tools on the floor found found none 😠 and thinking I cleaned up everything. I went and flew for two hours and landed. At post flight inspection, I found the box wrench was still attached inside the bottom gear access panel.
I'm a partner in an RV-8 that we did not build with Grove gear legs. I see on the Grove website that Grove no longer makes these for the RV's. Where can I get the torque values for the attach bolts, and any other good hints and tips for maintaining them?
Is there any reason why I couldn't drill the heads of the bolts and safety wire them to keep from turning while torquing the nuts from inside?
I've got the Grove gear on mine; annotated the plans with the Grove designated bolts and torque values. No easy way to check the torque every year that I've found. Stand on your head and bruise some knuckles.
This socket really helps. It’s almost trivial to torque the nuts. Aim the socket for the corner and it almost falls on the nut. Even with the stock gear tower openings.
I have no idea why Van designed the landing gear attach bolts to be inserted upside down. Torquing them is a royal PIA. After maintaining them for several years in the original configuration, I acquired a set of anti rotation clips from a fellow RV-8 builder. Using the clips, you install the bolts with the head of the bolt in the gear leg tower. Torquing the bolts is now a 10 second operation. A good description of the process can be found here.
I think this is a business opportunity for someone. A pair of nuts welded onto a rod the exact correct distance from each other.
The only problem I see with that is cosmetic. It requires more clearance on the underside near the covers and fairings, especially with the Grove or Sky Designs aluminum gear since it's thicker and the bolts are longer.
Bruce still makes those clips, and I don’t think the design has changed since he started. I’ve installed them on both of my RV8’s and a couple others using the stronger nuts, and in my case they fit under the fairing without modification. On Bruce’s airplane, he has the thicker Grove gear and the nuts protrude very slightly through the fairing. He just made a hole in the fairing to accommodate that - hardly noticeable. The demand for those clips is very sporadic. He won’t get a request for several months, then all of a sudden he gets calls for ten sets (40) of them. He just made a batch of them a couple weeks ago.
I drilled clearance holes in the fairings for the nuts. No more noticeable than the fuel vents and I can retorque them without removing the fairings.
Install the anti rotation clips inside the gear towers and reverse the bolts. Takes 15 seconds to torque them from the bottom. I installed them after 5 years of pain and agony. It’s a poor design from Vans.
The way I read the plans was to keep the bolts within 5 in/lbs thus increasing your torque wrench 10 in/lb per bolt swap should do the trick.
