If you missed it, there was a Saturday edition of the VAF News. You can read it here:
dr
RV White Pages Updated
Bob Collins -12 Update
lucas2696
Vlad the Amazing (Daily pic)
Leaky AD-42H …DonMcKee
Ironflight
Halleffect
RE Baffle Clean up …supik
Probable cause list updated
OFF TOPIC:
The VAF News - 7.5.2025. #6346. SPECIAL SATURDAY EDITION.
dr https://vansairforce.net/threads/rv-15-new-video-update-7-3-2025-the-new-final-tail.236109 omarf https://vansairforce.net/threads/paul-dye-flies-the-rv-15.236105/post-1854705 Edoorfly 9A https://vansairforce.net/threads/first-flight.236075/ SuperCubDriver Update...
vansairforce.net
dr
WDYDWYRTW? July 5-6, 2025.
…getting this weekend’s thread started. Hope you’re having a nice weekend. v/r,dr PS: Pic is 0845 am local DFW (storms and low viz around TX - not much flying)
vansairforce.net
vansairforce.net
Failure to start
I would get it inspected as it is by DAR as an E-LSA and then before you fly it run a flexible hose in it's place ;-) Probably not an option. Most any inspector is going to want evidence that the engine has been run on the airframe without any leaks.
vansairforce.net
lucas2696
Fuel tank sealant from 2002-2004
Does anyone know what sealant Van’s was recommending for fuel tank sealant around 2002-2004? I assume pro-seal. I have my tanks off, one of which the access panel on the root rib showed evidence of leakage (blue staining from around the screws). So I pulled the panel off and started to clean up...
vansairforce.net
closed end pull rivet not so closed
started the day chasing down an obvious leak in the left tank... after searching unsuccessfully for some sign on the outside we pulled the tank from the wing and found that several of the ?closed? end pull rivets for the z brackets at stations 5 and 6 were not so closed after all. these special...
vansairforce.net
Ironflight
F1 Milestone!
Had a few friends, two engine hoists, and a forklift over for a work party this morning…… Now I’ve got all sorts of things to work on! Baffles, cowling, AirBox…… and that twenty-five-year-old front seal….what fun!
vansairforce.net
Halleffect
390-EXP oil drain access without removing the lower cowl
The oil drain on the EXP sits right above the forward part of the lower cowl closeout. Making the close-out two pieces allows easy access to the drain with the cowl in place.
vansairforce.net
Baffling clean up
Routinely overlooked with carbed RVs...failure to seal at the air box inlet raises pressure in the lower cowl. Cylinder cooling is all about deltaP, upper cowl and lower cowl.
vansairforce.net
vansairforce.net
OFF TOPIC:
vansairforce.net
www.vansairforce.net
vansairforce.net
