The VAF News - 7.30.2024. #6137.
RV News That Caught My Eye Over The Last Day or So ….dr
__________________________
Tank Leak
Wirejock’s Skybolt Fasteners
…just a cool pic.
Firewall Penetration…Desert Rat PIREP
This is going to be somewhat specific to your installation, but I ran all that stuff through two 1" firewall passthroughs up high on the passenger side. One was for power wires and the other was for sensor wires. If you go this route you have to make sure they don't interfere with the brake reservoir or getting your battery out of the box if it's on the same side.
You might also consider running a few extra wires through and just capping them off for stuff you haven't thought of or might want add in the future.
https://vansairforce.net/threads/firewall-penetration-locations-for-a-rv-7a.228640/post-1782984
Panel Redesign …Carl Froehlich PIREP
I find figuring out how to mount remote stuff to take more time than the panel itself. The key point here is to make a lot of room for the associated module D connectors, and verify that you can actually attach or detach the connectors with the module installed.
For planning , I did the same paper doll approach as the panel. The photo is the current ride (RV-8). There is a lot more room in an RV-10!
https://vansairforce.net/threads/designing-a-new-panel.228625/post-1782903
OSH’24 Field Reports (PIREPs / News / Pics / Recipes)
WDYDWYRTW? (7/27-28/2024)
https://www.vansairforce.net/threads/wdydwyrtw-7-25-26-2024.228571/
OFF TOPIC:
PS: Older issues of the ‘VAF News’ can be found at:
