The VAF News - 7.29.2025. #6362.
DeltaRomeo
doug reeves: unfluencer
Staff member
RV-8 jonbo
Thermos
dr
supik Baffle Mod Update
Cyl #5 mod done. No flight data yet. Thank you all for the ideas!
OSH’25 PIREP
tom_paul
Great flight home to KLDJ from a great week! This was my first time flying in. The Fisk arrival was a blast. I loved the excitement of being part of that complex machine, with those awesome ATC people. Very impressive stuff! Flying the Chicago shoreline was a highlight, both coming and going.
APicard
RE: FMEA - RV14 Dual Alt / Dual BATT / SDS EFI
Not unless there is a need.
The engine bus and essential bus would be on one battery, the main bus (secondary power feeds) and starter on the other.
Normal start highlighted in green.
The wire sizes would support starting with both batteries if I opened the x-tie. (Highlighted in red) The GAD27 Keep alive would keep all the main items going throughout the start.
RE: FLAP HINGE PIN - Vote remove middle lugs or end run through aileron bracket.
I have no reason to think that either method wouldn't work fine.
On my 7 I split them in the middle simply because sometimes it's harder to get one long pin to feed through a piano hinge than two shorter ones. It took all of about 20 minutes to throw this setup together.
mulde35d’s RV-10 is Officially an Airplane
Mothership
OFF TOPIC:
