RV News That Caught My Eye Over The Last Few Hours ….dr
__________________________
Garmin Avionics Demo Before OSH (52F this Friday) …my home field. dr
If you would like to play around with Garmin avionics in a kiosk similar to what will it be at Oshkosh, with no crowds around and with a factory rep there to answer your questions one on one, stop by the location listed below between the hours of 9 AM and 11 AM this coming Friday, July 12.
From Brad at Garmin, “Kiosk will have 2 G3X Touch and GTN750. I’ll also be flying in a G3XT/dual GTN equipped 182.”
Use the maps here (note new road into airport that your nav might not show). DO NOT DRIVE ACROSS THE RUNWAY!!!!! Can’t emphasize that enough…. Please do not park on the grass, there is a septic system runoff out there.
Bring a chair if you need a chair.
(if you're not into maps):
52F airport,
West side, Charlie taxiway off Airway Blvd,
Look for the cars.....
![Screenshot 2024-07-09 at 4.20.12 PM.png Screenshot 2024-07-09 at 4.20.12 PM.png](https://vansairforce.net/data/attachments/44/44787-9a874d5b69044b6a572055dd531d9957.jpg)
![Screenshot 2024-07-09 at 4.19.50 PM.png Screenshot 2024-07-09 at 4.19.50 PM.png](https://vansairforce.net/data/attachments/44/44788-b440530367214045c9661deb5f551470.jpg)
Looking for left Quickbuild Wing in Europe
www.vansairforce.net
![Screenshot 2024-07-09 at 7.19.59 AM.png Screenshot 2024-07-09 at 7.19.59 AM.png](https://vansairforce.net/data/attachments/44/44782-aff6dade89a3b8812f7b050789251a12.jpg)
Blast Tube Love …Biggiesauls
I had the below 1,100 rpm stumble on my newly minted RV-9A (afp-150) after 30 minutes or more of flight time. Stumble would happen on taxi or worse on final if a touch of power was needed. I tried numerous combinations of heat sleave on various fuel related item fwf. What I did 2 months ago that virtually eliminated the stumble…. A 1" blast tube pointed at the mechanical fuel pump, no shroud installed.
Additional note: my RV9A has the new elastomer nose gear assembly. My concern is that all the new "structure" from this assembly inhibits the clean flow of air from behind the engine/accessory case area. The blast tube guides some air to a hot spot.
https://vansairforce.net/threads/cowl-flaps.228196/post-1779415
![Screenshot 2024-07-09 at 4.10.45 PM.png Screenshot 2024-07-09 at 4.10.45 PM.png](https://vansairforce.net/data/attachments/44/44783-10046c8938ad63f42028084570e3ffec.jpg)
WDYDWYRVTW? (7 / 6-7 / 24)
vansairforce.net
![Screenshot 2024-07-09 at 4.11.14 PM.png Screenshot 2024-07-09 at 4.11.14 PM.png](https://vansairforce.net/data/attachments/44/44784-029678ed334e4205f92436756fae978a.jpg)
Prop Vibration Solved …ERushing PIREP
Another success story... RV-10/ IO-540-D4A5/ Hartzell 2 blade prop. For 300 hours, I had an annoying 1/2 order vibration that I could feel in the seat and stick, even after balancing, rotating the prop 180 degrees and countless efforts looking for anything that I could think of that might be causing the issue.
After rotating the prop to horizontal at top dead center and rebalancing, the annoying 1/2 order vibration is gone.
As mentioned before, the 79024-S and extra 72155-S did the trick for me.
https://vansairforce.net/threads/prop-vibration-solved.145195/post-1779401
![Screenshot 2024-07-09 at 4.13.34 PM.png Screenshot 2024-07-09 at 4.13.34 PM.png](https://vansairforce.net/data/attachments/44/44785-5e1d46cb9325cb6b8a181af9708e6ce8.jpg)
OFF TOPIC:
![IMG_4659.JPG IMG_4659.JPG](https://vansairforce.net/data/attachments/44/44786-e9261881695370481c482fc625b10348.jpg)
PS: Older issues of the ‘VAF News’ can be found at:
52F airport,
Hi guys Our 2 year old RV14 got hit on ground by a Robin. The Robin taxied into our plane while we were refueling. Don‘t ask how, I don‘t understand it either 😢 The rudder and elevator got destroyed and we are already building new ones. The bigger issue is, that the wing of the Robin slid...
![www.vansairforce.net](/proxy.php?image=https%3A%2F%2Fwww.vansairforce.net%2Fdata%2Fassets%2Flogo%2Fvaf-icon-192x192.png&hash=253ac26c64e15348dec9ea91bd1c9a3e&return_error=1)
(what did you do with your RV this weekend?). Getting this weekend's thread started… v/r,dr
![vansairforce.net](https://vansairforce.net/data/assets/logo/vaf-icon-192x192.png)
OFF TOPIC:
Doug's Area ....The VAF News & my flying resume.
