The VAF News - 3.24.2025. #6303. Sun/Mon early news push.
DeltaRomeo
doug reeves: unfluencer
Staff member
Side hustle this weekend, so pushed out Monday’s edition when I had a free moment. Hope you had a really nice weekend.
v/r,dr
dr
First Flight: Randolf Gruener’s RV-10 | Westover, Massachusetts. RV-10 #41424
Daily RV Pic
….Vlad submits a beaut.
Mexican Mountain backcountry airstrip in Utah. The ground is still soft.
tom paul
RE: RV14/10 (Maybe others?) Rudder Fairing Light Cutout Delete
…mulde35d reply
Honestly, it was not hard. Last picture is after primer, you would never know a difference
RE: Engine driven fuel pump inlet fitting torque
RE: Building in shop without enough space to mate the wings
…PhatRV reply
I live in a small house that was built in the post-WW2 years. My garage cannot fit the plane with the wings, even when they are position in diagonal. I mounted the wings outside for one day to align the incidence angle and to drill the rear spar. After 24 hours, one wing was removed and the plane with 1 wing moved back inside the garage. There was very little room inside the garage. After the flap and aileron were fitted and aligned, the entire contraption was rolled outside the driveway, the wing was removed and the other wing was mounted on. The process was repeated.
This is the photo when the plane was outside the driveway with the wing incidence was checked and rear spars were pilot drilled. As you can see, the entire airplane could not fit inside the small garage. But with careful measurements, everything was came out okay. The airplane flies straight.
Q/A
Kizad
A:
Watzlavick
RE: Elevator Alignment …Mikeyb reply
I like you, agonized over that alignment. The alignment of the elevator rotation axis is probably more important than anything else. It’s really a kinematic nightmare to align the lines between the hinge points, the center bearing and the 4 rod ends. The line through my HS hinges was not perfectly straight nor do I think it’s possible with the construction tolerances the kit uses. Plus that due to the nature of the rod ends the minimum adjustment you can make is limited to a half turn of the rod end thread .025” IIRC.
What I decided to do was go ahead and get a decent match of the skins keeping the rod end measurement as close as I could and drilled the arm to the center bearing. Then I put it together with the inboard hinge bolt without a nut and moved the elevator over its range of travel and checked to see if there was binding by verifying the bolt would still slide back and fourth in hinge/rod ends. if it didn’t I would move the rod end half a turn to see if I could minimize it. I think I might have moved one. In the end it seems to work and fly wonderfully.
Speaking of Fuel Caps …Foghorn
Went to fly the plane today. When I was visually checking the fuel my left fuel cap pin broke. It’s been on the plane for over three years.
This is another reason to have a spare fuel cap in your tool bag. Took me a few minutes to replace and go fly.
OFF TOPIC:
