PSA: Rotax B-Regulator Connector Mount
I've seen a couple RV-12iS installations that have the newer Amphenol Round connector on the B-Gen Voltage Regulator that didn't have the VR connector mounting bracket installed. Rotax addressed the connector mounting bracket installation (951981 $61!) in the Service Instruction SI-912 i-024...
vansairforce.net
Sealant removal tool that I thought looked cool:
Fuel Tank Repair Suggestions
Good Day All! My 1982/88 RV-4 developed a fuel leak in the LH tank at the Sump and near the Forward attach point. Skipping the interesting bits, we were able to remove the tank and confirm the location of the fuel leaks via the ballon/bubble test. I removed the Fuel sending unit cover panel...
vansairforce.net
Michelin Pilot Tires ....dr
PILOT
Michelin Pilot Flyer, High Performance Bias Tires For Piston And Turboprop Aircraft Are Designed To Be The Best Tire Money Can Buy For Propeller Driven Aircraft.
*Trivia: The Space Shuttle rolled on Michelins ;^)
“The tires for the space shuttle undergo extreme conditions - from landing at speeds up to 288 mph to carrying loads as much as three times that of a Boeing 747 tire, which is the equivalent of a 40-car starting line-up at a NASCAR race.
The tires weigh approximately 230 pounds and each tire takes approximately six hours to build. The space shuttle takes six tires - four main-landing gear and two nose-landing gear tires - to land. The shuttle tires are inflated up to 373 psi and use nitrogen, which best maintains pressure in varying altitudes and extreme temperatures.”
Violent start when starting warm/hot motor.
Hello all - re attacking this issue on here and hopefully trying to figure it out: IO-540 with dual PMAGS. I have experienced, since having the aircraft, what I can only describe best as a violent kick when starting a hot/warm motor. This happens if I have just ran it for a few minutes (say...
vansairforce.net
My typical hot start procedure is mixture idle cutoff, no priming, throttle cracked. Usually starts pretty easily albeit with this thud.
Garmin Comm Issue
As illustrated on the pic above, I had an issue about a week ago with my #1 comm (top left of G3x screen). You can see it reads that 1215 (emergency frequency) is active, but it also displays the word “FAULT” directly below the frequency. This occurred on an IFR departure when tower...
vansairforce.net
First Flight: Dan Frazer’s RV-12iS | Mason, OH. RV-12iS #121322
https://www.vansaircraft.com/first-flights/dan-frazers-rv-12is/
vansairforce.net
OFF TOPIC:
vansairforce.net
www.vansairforce.net
vansairforce.net
