The VAF News - 11.14.2025. #6438. Side load control column, -4 inspection panels, Cowl heat shielding, Deburring technique, Nose breakout force.
DeltaRomeo
doug reeves: unfluencer
Staff member
Wishing you and yours a happy, safe and RV-filled weekend.
v/r,dr
The floor under the front seat area should be on with screws and come up easy. Its also the panel you can install foorwells for rear pax if you don't have them already. The aft floor is riveted, and it's no biggie to put access panels if you need. But, the best routing is often down the sides above the floor. I routed most everything down the sides . I also made sidewall closeout panels to keep rudder cable and wiring from fouling with passengers and such.
What I’ve done, and you could possibly consider:
. I sanded the inside of the cowl with 80 grit paper.
. Blow off dust with compressed air or vacuum it well with a strong shop vac.
. Wipe down with a clean rag and a solvent, like acetone.
. Paint entire inner surface with bilge paint from your local boat store. (This bilge paint is made to be used on fiberglass, and it is resistant to common boat bilge contaminants like fuel, oil, hydraulic fluids). I used a brush on the first coat to make sure it was forced down into the glass weave/pores. Used a foam roller for the second coat.
. Cover susceptible areas with the stick on aluminum shield sold by Vans. I also put 1/8” fiberfrax under the aluminum shield material in areas where the hot exhaust pipes are close to the cowl.
This has held up very well for 3 1/2 years now, including the bilge paint.
After the brake out force diminished to about 13lbs again I installed new Belleville washers. Here are various pics of the flange & fork surfaces as well as nut, steel washer and Belleville washers. Unfortunately I didn't take a picture of the lower fork surface where the Belleville washers meet the fork.
There is an odd streak on the inside of the right Belleville washer but I don't know if that has any significance. I hope someone with more knowledge than me can spot a smoking gun here
I revived my bushings only a week after ordering them! Awesome.
The only issue is the hole in my stick for the grub screw. I have the pre-wired sticks from tosten - and the hole is on the front side of the stick. This means the bushing angles the grip toward the panel, not away!
Your hole seems to be on the aft (pilot) side of the stick.
I think I have two options:
1. Mark the existing hole in the stick into the opposite side if the bushing, tap drill a new hole and then tap 10-32.
2. Somehow blind drill the stick on the forward side, to match where the threaded hole is on the bushing.
I’m thinking option 1 is going to be more achievable.
OFF TOPIC:
