FireMedic_2009
TASEsq
dnickerson46
mothership
www.vansaircraft.com
vas4vans
fixnflyguy
OFF TOPIC:
Electrical layout from engine to elec bus
I’m updating the panel to glass and rewiring. Attached is the general layout. 5-6 yrs ago DanH advised to put and ANL fuse on the firewall side before the B-lead enters into the cockpit. I believe he said the reason was in case the B-lead would ever short out going through the FW, it would blow...
vansairforce.net
TASEsq
Tip Up: Painting inside of canopy glass over roll bar
I’ve noticed on a few RV’s, that paint and dust and grime collect under the aft window between the glass and the roll bar. I was thinking of painting a strip of interior color (same as the roll bar color) on the inside of the glass to hide this. (and will likely install the window with clear...
vansairforce.net
dnickerson46
Nose gear fork reinforcement and bracket cracks
I did not build my -9A and during the recent condition inspection, I found the nose wheel fairing brackets were cracked. The original builder created two separate brackets on each side of the fairing and riveted the brackets to the fairing. The cracks are most likely caused by the back and forth...
vansairforce.net
mothership
SB-00007 REV 2 - Van's Aircraft Total Performance RV Kit Planes
Specifies inspection of RV-10 main gear weldments on fuselage kits shipped before January 28, 2021 and instructions for remediation when needed. This document supersedes SL-00033, which specified inspection of the same structure.
Main Landing Gear SB-00007 REV 2 - Supersedes SL-00033
Link - SB-00007 REV 2 Inspection and Replacement of WD-1201 Landing Gear Mount
www.vansairforce.net
vas4vans
New PMag install, weird Tach/RPM issue ...
Brand new PMag install, G3X Touch, the RPM indicates fine over 1400 RPM, but below that it drops to zero and stays there until you're above 1400 RPM again. Has anyone seen this? Brad said one of the phases of the generator may be bad, but the test to confirm that didn't show what he expected...
vansairforce.net
fixnflyguy
Van's fuel primer system
My plane has no fuel priming system. Apparently no one in over 20 years has ever felt the need for one. I give it a pump or 2 with the throttle depending on how cold it is, none if the engine is warm. It generally starts just fine for me. OTOH, a couple times I've had to cancel a flight...
vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
