The VAF News - 1.11-12.2025. #6252. Super rare Saturday collectable edition!!!
DeltaRomeo
doug reeves: unfluencer
Staff member
Had enough RV news to build up a Sat/Sun edition. Enjoy. Hope you have a wonderful weekend.
v/r,dr
Ironflight Rocket Update
mburch
…AMP100 Hall Effect & #2 Wire
I made a quick and dirty nylon spacer on the lathe and glued it in place:
jake14
…RE: Mixture cable to Avstar NNSS5 servo
That's the return line from the 1/2 Raven air-oil separator. It does a pretty good job of keeping oil off the belly for simple aerobatics.
TASEsq Canopy Crack Update
This canopy and I really aren’t getting along. An update: I used my scrap piece and tried to wick in some weld on 3. This did absolutely nothing. It went into the countersink and just sat there - didn’t seem to wick into the cracks at all. Not even a tiny bit.
Tim 8-A Panel Update
More eye candy.
I didn’t build the plane it was completed in 2014 by a well known member of VAF, CharlieWaffles (Mark) I purchased his plane 11/23.
The TT AP was becoming intermittent and needed to be replaced. The panel needed a few other upgrades it had GTX 327 and NavWorx.
Instead of the apparent choice, the Dynon AP, I decided to go the route of the Garmin AP I fly behind the G3X system in my 8a and it’s rock solid.
The Advanced EFIS and engine, monitor are also rock solid so as of now I see no reason to upgrade to a complete G3X. I’ll wait until the new Garmin PFD screens come out then decide if it’s worth making the change.
Along with the AP, I also upgraded
Legacy 750 to an XI.
The PSEngineering PAR100ex to PAR200B
The GTX327 to the GTX345.
I kept the NavWorx for ADSB on the main screen, and now have ADSB on the 750ix through the 345.
Advanced doesn’t have XM capabilities so I kept the XM receiver mounted under the panel.
kenpilot
Amadeus
OFF TOPIC:
