Regarding the front edge of the tip-up canopy frame: my gap between the frame skin and front top skin ended up being larger than I would have liked (a strong 3/32" - less depressing than saying almost 1/8"), primarily because until I was done riveting everything together and really got a good look at the opening movement of the canopy, I never quite understood what I'd read about raising the frame skin with a shim to help with clearance. Hindsight is 20/20. So I'm stuck with a large gap that I don't love. I did fill in the area over the hinges with aluminum, and after I get the front skin on I will put proseal into all of the subpanel flange gaps from underneath to plug all of those holes. So I think from a leak perspective, I'll be as okay as I can be.
My question: Is there a trick to making these subpanel flange gaps a little less unsightly, vs just seeing blobs of filler proseal every 5 or 6 inches? The overall skin gap won't bother me as much if I can somehow create a fairly uniform looking surface. Does it work to simply fill the whole gap with proseal to create a flat surface (for aesthetics, not necessarily as a gasket)? Can I add some sort of die to the proseal to just make it black? I think with the right paint it would blend in okay then. I've heard proseal can be painted, but does it really stand the test of time?
I've moved on and come back to this canopy multiple times over the last year, and I'm finally at a point where I just need to get the canopy on, since I'm now down to finishing the FWF and panel. I've been putting this off because the gap irritates me and I want to try to make it disappear as well as I can so I don't snarl at it every time I look at my beautiful plane.
