Template leading edge light
azonic75
Anyone notice that the template provided by Vans (OP-52) is not true size. To spar le time at the photocopier…. Any one recall how much to upsize? 103% needs to be perfect since some components are pre drilled
My template printed to the correct size, however I use a Canon large format printer for all plans documents and print on 11x17 paper. You might try finding someone with a similar setup in your area.
Print directly from the PDF
I too printed mine to a large format printer and it was correctly sized. The print that arrived with the parts was well off scale.
OP-52 Template
I just had a couple OP-52 prints on the shelf checked for correct size of the template and the ones we currently have in stock are the proper size.
If you are printing the template from a PDF it must be printed on an 11 x 17 sheet with no resizing or shrink to fit, etc.
