Anyone notice that the template provided by Vans (OP-52) is not true size. To spar le time at the photocopier…. Any one recall how much to upsize? 103% needs to be perfect since some components are pre drilled
My template printed to the correct size, however I use a Canon large format printer for all plans documents and print on 11x17 paper. You might try finding someone with a similar setup in your area.
