tail wheel spring WD409
Brian Cornes
I'm New Here
hello, Im building an RV7 and having difficulty fitting the tail wheel spring attachment (WD409) to sit flush on F712 has anyone else had this problem?
I'm trying to fit the WD409 onto F712 with the 2 keeper rivets. I've drawn the position of 409 onto F712 as laid out in drawing 27.
When I position 409 onto F712 in that position i'ts 'held off' F712 by the weld. I've asked Vans support if its ok to increase the size of the cutout to clear the weld, but as yet I haven't had a reply.
I can't mount 409 lower down because of the edge distance of the top two bolts is compromised .
I would appreciate any advice, if anyone else had had this problem what did they do to resolve it?
many thanks
Brian
