rdockery_3
Active Member
My 2011 RV12 trim button isn't working. I went out to the plane this morning and after I started the engine and was going through my checklist my trim stabilator trim wouldn't work. I shut the engine off and kept pushing the button and there was nothing. I couldn't hear any sound coming from the servo or anything. I took the cover off and didn't see anything disconnected. My next step was going to be looking behind the instrument panel but I wiggled the switch a little bit and it started working. So, I thought I had found my problem, I figured it was a loose connection on the switch. Then it quit working again. You can hear the servo now when you push the switch but there is no movement. I'm still going to look behind the panel to see but i don't think it's a loose connection because the servo is obviously getting power. Any troubleshooting help would be helpful.
