I just picked up from the paint shop and found that there is no stall horn ("horn" meaning a warning over the headset) or angle-of-attack sounds. AOA does work as the indicator on the G3X screen still displays.
The paint shop would not paint with the wings removed as this was not covered by their insurance policy (they said I would need to remove wings myself when I got home and primer the unpainted area when I put on the gap filler). So logically I assume they did not remove the wings. However I wonder if people there were curious and pulled the wings to take a look and disconnect something. Is that possible?
