I've seen some small variations in fuel pressure since first flight, but on the way back from Oshkosh the variations became larger and more rapid. The engine ran flawlessly for the entire trip. Turning on the electric boost pump moved the average pressure up as you'd expect, but the fluctuations didn't go away. Here's a Savvy screen grab from the last flight before I left home for OSH -
and one from the next-to-last flight before I got home -
My RV-7 flies with a Superior IO-360 engine and G3X Touch avionics, including the original Kavlico pressure senders that came with the Garmin engine sensor kit in 2016. I'm on my way to the airport to double-check fuel line connections and bleed the fuel line to the sensor manifold. If the problem still exists after that, it's either the mechanical pump or the pressure sender.
I've been through some fuel pump failure threads here on VAF and this variation doesn't present like the failures I've read about - but I'm not an expert on mechanical fuel pumps. I'm leaning toward a sensor problem since I've read that the Kavlico sensor elements wear over time. Any thoughts from the experts on VAF?
Many thanks -
Dave
Many thanks -
Dave
