I see flyboys do one for the 8 which looks a nice solution but doesn't work on side by side RVs
Any neat ideas on a latch/ stop that allows you to have the canopy open a few inches for taxying ?
RV 9 slider.
Hi NigeDo you "need" a latch for taxy'ing? I frequently taxy my RV9A when its hot weather (yes it happens occasionally in the UK) and just slide it back 6" or so and it stays there, I close it and secure it during my power checks and have never felt the need for a latch. Your mileage may vary of course.
Nige
Carl do you have a pic of this setup on your canopy?I did a McMaster Carr locking detent on a fabricated aluminum l bracket which mounts under the rear canopy frame with a small notch in the canopy rail for the detent pin. Reason I needed it was magnetic interference with Manometers or AHRS unit mounted behind the bulkhead on RV7. Works great and found the idea on here. It was super easy and works great. I'm sure the thread is still here...did it around 2013 if that helps in your search if interested....
McMaster-Carr. Part number 8480A1.
I drilled one hole in the canopy rail to allow the canopy to be held about 6 inches open (for taxiing or parking in the sun) but could have drilled multiple holes for multiple positions.
I like that. Simple easy solutionDont have a picture but I riveted a 1" piece of hinge to the inside of the rail about 6" back and just flip the hinge over the track to stop the canopy rolling back while taxiing or starting the engine. I flip it back after I close the canopy in case I need to get the canopy open in a hurry.
Figs
This, FYI, does not work on side-by-sides, as the opening of the canopy rail faces inward instead of outward, so the "plunger" can't be mounted on the rail.EZ-STOP Gen 2
This is for anyone who has a slider type canopy and would like to have (or already has) an intermediate "stop" to keep the canopy from moving further aft when entering/exiting (think -8 solo). The universal, spring loaded plunger type has a flat mounting face and countersunk holes (for...vansairforce.net
Great solutionHere is what I did on my 6. Short length of 3/16" brass rod threaded at both ends 6-32 for machine screws. This makes the rod captive in the hole
This is a great idea, is it just the force of the canopy acting on the rod that prevents the rod dropping back down?Here is what I did on my 6. Short length of 3/16" brass rod threaded at both ends 6-32 for machine screws. This makes the rod captive in the hole
Agree, great solution. Even found a pre-threaded 2” aluminum binding post in the hardware drawers at both my local Ace and TrueValue stores. Ended up being a 30 minute project. Thanks for the idea!Here is what I did on my 6. Short length of 3/16" brass rod threaded at both ends 6-32 for machine screws. This makes the rod captive in the hole
That is true for my installation. On the taildragger the canopy weight easily holds the pin up. Then if you want to release it all you need to do is push the canopy forward slightly.This is a great idea, is it just the force of the canopy acting on the rod that prevents the rod dropping back down?
I like this one. Think I’ll steal it for my RV6. Great idea. Thank you.Here is what I did on my 6. Short length of 3/16" brass rod threaded at both ends 6-32 for machine screws. This makes the rod captive in the hole
mines a taildragger so think this will be fine, im off to the hangar !!That is true for my installation. On the taildragger the canopy weight easily holds the pin up. Then if you want to release it all you need to do is push the canopy forward slightly.
If you wanted it to stand up by itself you could drill the canopy deck lower hole a bit larger and use a tight fitting rubber grommet on that hole. The friction should nicely hold the pin up.
This is an elegantly simple solution!Agree, great solution. Even found a pre-threaded 2” aluminum binding post in the hardware drawers at both my local Ace and TrueValue stores. Ended up being a 30 minute project. Thanks for the idea!
View attachment 89792View attachment 89793View attachment 89794
