Hey guys,
Just got the dreaded “clunk” or “thunk”. My airplane is an RV-8, with a Lyc IO-360A1A and a Sky-Tec LS starter. I’ve been flying 17+ years and 1900+ hours.
In the past, the solenoid issue was very predictable. It would start happening intermittently when warm and get worse and worse. I’ve replaced the solenoid with a BWD unit 2 or 3 times in the past and I was good to go. This time it seems a bit different.
The clunk is happening even when cold. I ordered a Standard part but then realized I had a spare BWD in the hangar. I installed the BWD and no joy. I thought it might be dead since it’s been sitting in the hangar for a few years. I then installed the Standard part and it worked. Great, problem solved I thought. Cowled it up and prepared to go fly. No joy on start up. Pulled the airplane back into the hangar and went home.
I think something else might be up. I don’t believe it to be the battery, a Concorde RG-25 X/C. It’s relatively new, about a year old, and showed no signs of decreasing starting performance. I’ll check the open circuit voltage, but I’m pretty sure it’s 12.5 v +.
I wired my starter circuit per the Sky-Tec optional Experimental wiring diagram shown here:
The only difference is that in place of the pictured starter switch, I have a push-button switch on my Infinity stick grip wired to a 20 amp relay sold by B&C. I also have a common toggle switch on the panel that bypasses the switch on the stick. It doesn’t however bypass the relay. I can probably wire a jumper to bypass the relay, but as long as I’m going to be under the floor, I might as well just replace the relay.
I’ve looked over the Sky-Tec troubleshooting guide but I’m a little hesitant to take those measurements while attempting to start. Something is drawing down the voltage enough to de-power my VM1000C engine monitor display. I can certainly measure voltage drops and resistance in a static condition and that’s my next move in addition to checking the battery.
Any other ideas, on how to methodically proceed with troubleshooting?
At almost 20 years and 2000 hours, the relay and the starter certainly don’t owe me anything. But I don’t want to sink money into a starter only to find out it’s something else.
If I do replace the starter, I’m interested in replacing it with a B&C unit. Being a fuel injected airplane, I have the induction snorkel that goes from the left cowl inlet to the forward facing fuel servo. Do you know if the B&C starter has the same form factor as the Sky-Tec and will it fit without modification to the snorkel?
Thanks for your help!
