K=1/2mv^2
I'm New Here
E-mail exchange with Tim at Sky-Tec Hartzell
To: Sky-tec (Hartzell)
We have the Sky-Tec 149-12XLT in our RV-14a with the IO390 motor. After 150 hours of operation, we got the "Click" no start. After pulling and cleaning the solenoid we went an additional 50 hours before the next "Click" no start (@200 hours). Do we have a bad Solenoid or Is this typical behavior? Other RV14a owners have had similar problems. Looking for a long term fix. I do like this starter from a weight standpoint (6.5 pounds).
We have a earthX battery and have 13.2 VDC measured at the the Solenoid.
Thanks for your help.
Jeff
From Sky-tec (Hartzell)
October 2025
Hi Jeff,
We have found the external solenoids used on all the legacy Sky-Tec series starters not to be as robust as we would like. To that end, we sourced and are currently using a different solenoid vendor that seems to have reduced solenoids issues. These later solenoids are available on current production starters but are not available for retrofit in the field. Starter replacement would be recommended using your current unit to fulfill the core requirements.
Regards,
Tim
Timothy Gauntt
Thanks for the info Tim,
With regards to the Sky-Tec 149-12XLT starter:
The newly Sourced solenoids that are “available on current production starters”, do the starters have the identical part numbers?
Is there a differentiator, between the Old and the New?
I do understand that the new Solenoids are not backwards compatible.
Thanks, Jeff
Hi Jeff,
Not really as this was a running production change.
Regards,
Tim
My Thoughts:
Appears Hartzell has sourced a new solenoid for the Sky-Tec 149-12XLT, beginning late in 2025. Although this new solenoid is not backwards compatible (Allegedly), It did not trigger a part number change, making discussions about legacy vs New, Difficult.
Our original legacy solenoid slowly developed small groves that the actuator hangs up on (click). Developed a procedure to get the solenoid partially engaged to give us a one time start, allowing us to fly home. We replaced, and now fly with a spare Napa Part #: ECH ST421starter solenoid, for our legacy Sky-Tec 149-12XLT starter.
Jeff
October 2025
Hi Jeff,
Regards,
Tim
Timothy Gauntt
Thanks, Jeff
Hi Jeff,
Regards,
Tim
My Thoughts:
