Show Us Your Panel
Budget VFR Panel...
I’m re-building a 6A. The original panel was analog with cast-off, but functional equipment. Items from Piper, Cessna, Terra, etc. were used in the spirit of simplicity and low costs. I don’t think anything was purchased new for the original panel. I’ve tried to keep that theme going from the original builder.
A friend was able to scrounge a big piece of .063” 2024 from a dumpster. A friend put a nice 90* bend on it with his brake. After a few hours in & out of the -6, I had the basic blank. I added .75” extra to the lower portion. Still high enough to clear occupants’ knees. The only new item on the panel is the GTR200. It’s just too good of a value on a single COMM / VFR aircraft to pass up. Even the air vents were scrounged from the dumpster. I’m amazed at what people will throw away.
I’m currently working on wiring the panel, at home. 115*F is too hot to be working in the hangar.
This is what I had to start...
Current progress
This is what I’ve been able to get done...
Here is my panel evolution. Original, 1st upgrade from last year and the newly finished panel.
Day VFR to full Glass conversion
Not 100% done with electronics, but my dash is new and cut and powder coated.
RV6 Panel
Here's my old school panel. 180 hp// fixed pitch .Super light.I love it. (.....because I was inverted ....;)
RV-6 panel
My RV-6 panel installed 2014. 2021 upgraded to Dynon HDX and Aero 660.
New RV-6A
Day VFR RV-6A trying to keep it light and simple. Trial fit before priming and topcoat paint. Final installation will be after the windscreen has been fitted.
IFR Panel (Dynon with a Garmin 175) to powder coat to tomorrow.
Going to look and work good.
Panel design (removable middle section) has been a good learning experience. AFS support is great.
SNIP
You will never regret taking the time now to end years of pain from a panel that you have to crawl under to do anything.
Of note - I’m working a panel for an RV-6A builder (Dual SkyView, GPS-175 and Garmin NAV/Comm). On this panel we made a bottom apron (like the stock RV-10 panel) to mount all the stuff that stays in the plane when removing the panel (switches, cabin heat, engine control cables and such). Once the top portion of the panel is out you have full access to all this stuff. When installed, panel plus apron height remained the same as the stock RV-6 panel.
Carl
Never on your back with your head under the panel…..
New RV-6 panel
Here's a new panel we just completed for an RV-6 in our hangar. From mid 90s VFR to modern IFR for a local airline captain.
I've had my 6.9i since 1 December 2018... quite a few hours of avionics yoga were spent under the riveted panel, wedged between the manual flap handle and the throttle quadrant... from a pure VFR yellow panel into today's latest iteration :)
PS
The right side of the panel is usually covered by the iPad mini in a Xnaut cooling case on a RAM mount running the very popular (on the old continent) SkyDemon app.
From 1990's VFR to modern Garmin! RV-6A
PS
What's on your firewall ?
Aaaah... no clue since I'm not the builder. But it is some kind of sound isolation alu foil covered mat about 5mm thick, and knowing the pro builder, must be fireproof too.
The old panel, quite neat for a steam gauge setup but it was hiding some egregious wiring crimes and the partial remains of a vacuum system.
I ended up replacing all the wiring and starting fresh, requiring quite a few hours in the following position
At the same time I went through the entire plane and fixed anything that needed it and replaced anything made of rubber, or otherwise old and worn. The other big one was conversion from a wood fixed pitch to a constant speed Whirlwind. It was a tricky job to modify the quadrant for an extra lever, but it all worked in the end. Installing the crotch strap for the new 5 point Crow harnesses took most of a week also, though well worth doin.
Since the tipper canopy panel removes with just a few screws, I put everything through a big milspec connector, except the audio which has its own connector. This makes removal for maintenance super quick. All the switches are APEM milspec parts, no automotive grade nonsense here!
Since taking this photo I’ve mounted the iPad back where it was before, which is why there’s the USB power on the new panel
For UK/Europe touring I think this is just about perfect. It only has an O320 but an empty weight of 1030lbs :)
IO390,
Beautiful work! Nice looking plane! May I ask what the white plastic items are around the larger wire bundles? Plastic adel or "P-clamps"? And what is the black under them? Looks like a great way to tidy the bundles. Stealing ideas for a Bucker panel I'm wrapping up. Thx!!
Bob
IO390....
I just noticed that your struts are mounted up side down. If you flip them over, the canopy will slow it's opening speed for the last few inches and not come to a clunk! as it tops out.
IO390,
Bob
Thanks! They’re just nylon P-clips as you suggest. I put some tesa wiring loop tape around the wire where it’s clamped. Some example links:
Finished the G3x panel upgrade in my rv6. Loving the capabilities.
Sport EX, EIS 4000, GNC 355, GMA245
Out with the old and in with the new. Aerotronics Inc. in Billings, MT did the work and they did a great job! I went with a Garmin G3X system with a GNX 375 and Garmin autopilot.
Carl
Carl's #1 rule: "build so you do never have go inverted under the panel.
I can barely call my panel "mine" , yet in reality, my new RV-6A panel was really a "Carl Special". Tom Doran also helped immensely.
Carl painstakingly taught me along the way. I can be a pain in the a%$, yet he hung in there with me.
From the initial design to v8.
It will make my plane very capable.
https://drive.google.com/file/d/1KNl9ThG5AfXBRcJfFcwVE3P0yGr1tnYT/view?usp=drivesdk
https://drive.google.com/file/d/1EHdzwZqjmh8Z-0tKTVQ0CyrlPiwXG-wM/view?usp=drivesdk
This would not have been a plane at all without his outpouring of knowledge, and experience.
I've been looking forward to posting here for over a year.
  1. Dynon 10" displays x2
  2. Dynon Auto pilots (roll + pitch)
  3. Dynon A/P panel knobs and AP panel buttons
  4. Dynon 2020 GPS
  5. Dynon ADSB
  6. Dynon heated and temperature controlled pitot
  7. TC flap controller
  8. Garmin IFR 175 GPS
  9. Garmin 255 Nav/Comm
  10. Garmin 345 intercom
  11. LED landing lights
  12. LED Taxi light
  13. LED position, strobe, Nav lights
  14. Guarded switches and switch breakers
  15. Push button start
  16. Hands on sticks ( A/P disconnect, PTT, trim, and flaps)
  17. Pilot vs Co-pilot flap selector
Daddyman
Dynon IFR, 10’ skytouch PFD, D10 as back up, 2 axis autopilot with ACM module.
Will have iPad to the right
the panel is done now, second screen that was planned several years ago on hangarflying is installed, no regrets except that I did not get it done sooner.
Just finished a big panel upgrade on my -6 a couple weeks ago. I’ve put about 20 hours on it since and amazingly, I haven’t had to rip it back apart to fix anything yet. Now I just have to decide whether an engine monitor is next or dual P-mags….
Very nice @lucas2696 👍
Very similar to mine... I will not recommend P-Mags (that's another subject which I covered here à few times already) but did replace my dying VM1000 with a single G3X GDU 470 which is used as an EMS and MFD, see post above. I was able to barely have it fit without any mod to the bulkheads in front of the panel, and I'm super happy about all the data being acquired thru a flight.
Garmin doesn't like it too much as they would prefer us to buy glass real estate, and this non-standard config took some programming time, but real happy now.
By the way, love your paint scheme, same as mine as in somewhat old fashioned, but reminds me of drag racing, shoppers and so on, man I'm showing my age now :ROFLMAO:
Echostar7,
Nice clean look.
Daddyman58
Thanks, it's really nice to get the second display,
The flight plan shows up on both displays, baro setting syncs across as well thru display link. The second display has adsb, engine data and air data independently wired to it so those don't rely on the main display. Both power off from the main switch
