Hello,
I am new to the community, so excuse me if this has been discussed before; however, I couldn't find a post. I have been working on the practice kit included with the RV14 EMP kit, and I bought a couple of other practice kits before I get my feet wet on the real thing.
While building the practice kits, you go through drilling, match drilling, and deburring all surfaces. However, Section 5 of the builder's manual clearly states the following.
"Van's produces two aircraft kits with the holes punched final size (the RV-12 and RV-14*). No deburring is necessary; dimple
the holes and assemble the parts. These final-sized holes are manufactured using specific tooling and tight tolerances to work
with all commonly available dimple dies. By "work with," we mean that the holes may be dimpled without fear that the hole would
crack prematurely before the expected fatigue life of a conventionally drilled, deburred, and dimpled hole."
Would it be proper to think that no deburring will be needed for the 14, and is this the standard practice that everyone is following? Or is this in error thinking that the parts were laser cut and now they arent so we need to go back to deburring again? My father built a 10 and spent much time deburring all surfaces, ribs, and holes.
I would like to hear what everyone who is out there building the 14 is following.
Thanks much! Randy
Thanks much! Randy
