SD-00001 Trim servo replacement
skydiverlv
After much searching I have been unable to find the thread related to the Ray Allen trim servo inspection/replacement. I thought I remembered someone had used the original tray mount with some modification. Trying to get lined up for a replacement next month. If anyone can locate, it would be appreciated.
Sorry, didn’t think to take any photos, but I used the D-sub connectors and simply wire tied the connector and harness to the side of the tray. I liked this solution better as it didn’t put the sharp bend in the wire at the connector like if it’s mounted in the tray cutout.
Larry, I could not find it using Search either. Had to look through my old posts.
BTW, don't use the old tray. That would take more time and effort than just buying the kit and hardware bag and be a less satisfactory solution.
