I sanded and polished the aft edge of the canopy where the BIG TRIM was done with the Dremel SuperMax cutoff wheel.
First P80, then P180, P400, P800 then Novus polishes. The edge is nice and shiny, now. Looks good. Feels good.
After polishing the edge, I put the final masking tapes on prior to applying the Sikaflex products. The green tape will keep the primer from getting places it's not wanted. After pulling the green tape off, the yellow tape underneath will keep the Sikaflex 295UV contained within its borders.
Now, I just need to recruit two helpers from my offspring to assist. I think one son will reside inside the fuse to tool the Sika along the inside horizontal edges on each side and along the inside of the hoop, then pull the yellow Frog tape. The other son will help with attaching the side skirts containing Sikaflex with clecos. We will both tool the exterior Sikaflex, then pull the tape. I hope this works!
