As I've mentioned my RV8 didn't come with a POH. So in my quest to create one, and get to know my airplane a little better I have been doing "tests" here and there and keeping notes. One thing I didn't have was VSpeeds.
My airplane is built pretty close to plans, BUT I have an IO-360 and Catto 3 blade which has some noticeable characteristics that are different and would probably make other RV8 VSpeeds not applicable to mine. So using the Kitplanes article as a guide https://www.kitplanes.com/sawtooth-climb-performance/ I decided to do my own.
Yesterday I flew the test and built the spreadsheets and graphs. First thing I noted was that I probably could have gotten prettier graphs by adding more data points. But it seems I got the general idea with the data that was collected. The only one I'm not certain of is VMaxGlide, because you're actually using angles on the curve to get the correct number.
Some interesting points- The Catto barely makes 2100 RPM Static (66" prop 75 Pitch) and flat out at 6500 it turns 2750 RPM. I *think* that means I'm giving up performance (vs CS Prop) at lower speeds and during acceleration- however the prop does take a big bite so I'm not certain of this.
I *think* the reason some of the climb rates are the same (or very close) is that at the higher airspeed, Full Throttle generates more RPM, thus more HP or perhaps more efficiency from the engine / prop combo. I didn't record RPM for the various test phases.
Also, I was significantly lighter than Max Gross, being solo and not wanting to subject a passenger to my test flying.
I chose 3000-4000 MSL as the test altitude to give me the best idea of what the airplane is doing shortly after takeoff.
My primary airspeed indicator is in MPH, so I apologize in advance to the purists (myself included) who prefer Knots.
Any comments or corrections would be welcome. Fire away.
